Old 07-10-2003, 12:21 AM   #1
Merl4
Rear end swap
I'm removing the 6 lug stock rear end from my 1968 StepSide. I'm open for suggestions as to what make or model or rear that will fit and give a comfortable gear ratio.
Thank You.
Merl4 is offline   Reply With Quote
Old 07-11-2003, 08:45 AM   #2
crazy longhorn
Fabricate till you "puke"
71-72 will get you into a 5 lug axle in the 1/2 ton trucks. the rear diff is aprox 1 1/2" wider overall, but shouldnt be a problem. (bolt in). as far as ratio, for a 3.73 look at the I 6 stick trucks for a donor......V8 auto equipped trucks should have a 3.07 gear. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-11-2003, 05:15 PM   #3
krue
Designated A-hole!
krue's Avatar
What he said....and welcome to the board!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
