Old 10-09-2013, 06:18 PM   #1
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Side marker light surprise...
As strange is this may seem I just recently discovered that my 68 has never had side marker lights . It has the actual reflector devices but there are no lights installed in them . Even though these lights are not required by state law I want them for obvious safety reasons . I ordered a set of the light sockets from LMC but need a schematic to install them properly. Can anyone on here post a really good idiot proof schematic for me ?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 10-09-2013, 06:42 PM   #2
BIG69GMC
BIG69GMC's Avatar
Re: Side marker light surprise...
I would think you should be able to tap into your other front signal harness using good and weather proof connections. ofcourse this would cause them to flash when you use your turn signals. Im not sure if thats the operation your looking for?
BIG69GMC is offline   Reply With Quote
Old 10-09-2013, 06:48 PM   #3
Sillyoldman
#16876
Sillyoldman's Avatar
Or tap into the marker light wire for a constant. It should be easy to identify with a wire test light.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 10-09-2013, 07:36 PM   #4
HIGHWAY BY THE SEA
I was considering that but then I looked at the wiring schematic on my 81 C10 and it requires all kinds of power wires that run all sidemarkers together and share common ground wires. I figured that the 68 might like we use a similar setup . I do not want them to flash when I signal . Was it normal for these trucks to not have side marker lights installed in them ?
Old 10-09-2013, 07:44 PM   #5
BIG69GMC
BIG69GMC's Avatar
yes its normal. Im not exactly sure which years had them, im thinking the "newer models" like 71/72 had them? i know the first years did not. You could just tap into each nearest marker light and test with a test light to make sure they stay constant power when you have your signals on. You would have to wire each socket into each corner harness and that should be all. You wouldnt have to worry about running grounds for each one or connecting them all together. You would have to play with one to get it figured out then you would know what to do on all the others. Hope this helps get you started. Seems alot more complicated than what it really is.
Old 10-09-2013, 07:49 PM   #6
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Make these larger.
If you can't, get the big one from the Forum download or PM me...I can't send a big one using the Forum.
Obviously, you don't have to go all the way back to the HL Switch....Just find the right (correct) wire, and, "Tally Ho!"
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 10-09-2013, 07:58 PM   #7
BIG69GMC
BIG69GMC's Avatar
Nice Job Mag!
Old 10-10-2013, 12:35 AM   #8
68c10airstream
68c10airstream's Avatar
Hey highway by the sea, just checked my stock 68 c10 and wire the side markers the way gm designed them to operate: Headlight switch off, turn signals on/ 4 way flasher the side markers turn on at the same time, headlight switch pulled out, side markers are off when the turn signal lights up, then when the turn signal light turns off the side marker turns on. The lesson here is if wired this way always make sure the front park/turn signal bulbs work properly before repairing the side markers. I believe gm did this to get the attention of people to avoid accidents as alternating lights between side markers flashing and turn signals flashing is really hard not to notice. If you want me to check for sure i can later as i'm tired and going to bed, wife and i have worked on our house for days on end to get ready for winter! Good luck, Brian F.
68c10airstream is offline   Reply With Quote
Old 10-10-2013, 11:12 AM   #9
Keith Seymore
Keith Seymore's Avatar
The alternating lights were used to minimize the current flow through the lightest duty component (typically the headlamp switch).
Having both (side marker and turn) on at the same time increases current flow, heat and therefore decreases the durability of the components.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 10-10-2013, 12:45 AM   #10
Mister-B
It's normal for a '68 to be reflector only. My '69 came the same way from the factory, and I think it's cool. If I remember, they started lighting late in the model year of '69. Keep in mind that the reflector only are just that. They reflect when a car's lights shine on them, so it's not like you're a complete sitting duck
Mister-B is offline   Reply With Quote
Old 10-10-2013, 06:54 AM   #11
Andy4639
Old member
Andy4639's Avatar
Wink Re: Side marker light surprise...
For the 71 model the front side lights flash but the rear do not. Factory.
68 was the first year with side markers reflector's and no lights. 69 was reflectors unless you ordered the truck with the lights. Most trucks didn't have the lights ordered. Later years they were required to have them.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-10-2013, 10:13 AM   #12
jmorri34
jmorri34's Avatar
Ok I just got done doing this exact same thing. Now I did not want my sidemarkers to blink but just wanted to have them on as solid side markers. All you have to do is when you get the pigtails they will have 2 wires. It does not matter which wire you use but all you have to do is tap into the front blinker lights in the grill. Now on the front blinker there is a solid posetive and a blinking posetive, tap into the solid posetive with one pigtail wire and the other goes to ground. On the backs you can do the same exact thing, just tap into the solid side of the rear brake light and the other goes to ground. Mine is done this way and works perfectly, no electrical issue or anything and they are on solid when you pull the headlight switch on. Super easy!
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline   Reply With Quote
Old 10-10-2013, 11:15 AM   #13
Keith Seymore
Originally Posted by 73737373 View Post
Fed Hiway Trans Safety Board mandated side reflectors only on 68 model trucks. Did not have to be illuminated until 1969.
Thanks for the input.
I knew '69 was the first year for Federally mandated side marker lights for passenger car but wasn't sure about trucks.
K
1979-1986
1986 - 2019
Old 10-10-2013, 11:43 AM   #14
Mister-B
K
It's not quite that simple. Depends on when in' 69 the truck was built. Mine was an early 69 build and doesn't have lit markers. No wiring or evidence of wiring at all
Old 10-13-2013, 08:43 PM   #15
HIGHWAY BY THE SEA
Thanks for all the fantastic help with this issue ! I have the front ones hooked up and they work perfectly with the blinking like was described on here. I just wired up the right rear one and I am lacking the wire splices to do the left one tonight . This normally would not have taken so long but I broke my hand recently and I've had to do this mostly one handed .
Old 10-10-2013, 11:14 AM   #16
73737373
1968 Custom SWB, 327/3 speed OTC
1969 CST LWB, 402/400
1970 CST LWB, 402/400
1970 Sierra Grande LWB, 350/350
1971 Cheyenne LWB, 350/350
1972 Cheyenne Super LWB, 402/400
1972 Sierra Grande LWB, 402/400
1979 Silverado LWB, 350/350
1984 Suburban
1990 454 SS
1991 Silverado, X-cab, 4.3/5 speed Getrag
2005 Silverado Crew Cab
Corvettes: 75, 77, 78, 93, 96
73737373 is offline   Reply With Quote
Old 10-15-2013, 08:02 AM   #17
73737373
Good Lord, I know what you're talking about....chasing blinker/brake/parking/dash light gremlins myself.... NEVER fun.
1984 Suburban
1990 454 SS
