Old 10-12-2013, 07:07 PM   #1
earl84
Wiper motor/switch help
This is what my wiper motor looks like. Can anyone confirm it is a single speed motor? It has 4 terminals, and I am not really sure which terminal is for what. The original wiring has been replaced, and I took pictures of the old and still have a pile of old wiring, but it was kind of funky and now I can't tell what goes where. The PO just had a toggle switch to run it, so it only ran in one speed. I am asking so that I can order the correct wiper switch as well as get this hooked back up. I just finished installing an AAW Wiring harness, and this is the last thing to do.
Also, can I order a two speed motor and a wiper switch with two speeds and a washer function? My truck has a washer bottle, but no pump as far as I know. Any help is greatly appreciated.
earl84 is offline   Reply With Quote
Old 10-13-2013, 12:54 AM   #2
Captainfab
60-66 Nut
Re: Wiper motor/switch help
That does look like a 2 speed wiper motor without the washer pump. You can buy replacement washer pumps, but I don't know if they come with the 'propeller' that goes on the shaft to drive the pump. Here is another thread that should help you with the wiring.
http://www.67-72chevytrucks.com/vboa...t=wiper+wiring
Old 10-13-2013, 10:19 AM   #3
earl84
Thanks, Captain, I will take a closer look at these and figure out what I need to do. Appreciate it.
Old 10-13-2013, 12:34 PM   #4
61K10
61K10's Avatar
can you put a 63-66 wiper motor in a 60-62?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-13-2013, 11:57 PM   #5
Captainfab
60-66 Nut
I know that the '60 uses an oddball wiper motor. I'm not sure if '61 uses that same one, or if '61 and '62 use the same motor. I've never tried to use a '63-'72 wiper motor in a '60-'62. Like most things, anything is possible with enough determination.
