10-15-2013, 08:29 PM | #1 |
Issues with charging system
So I am having trouble keeping my battery charged, I charge it until my trickle charger says it's good, and after 2 starts with my truck it is struggling again. I've had my alternator (1-wire 90A, brand new) load tested, and the battery independently tested, and both are good. The wiring is a brand-new Painless 18 circuit setup.
Are my grounds faulty? I've relocated my battery to the rear, and grounded the negative terminal to the frame. The motor is also grounded. The battery cable is 2 awg from Home Depot. I also use a Ford-style remote solenoid, which shouldn't really matter. |
10-15-2013, 08:47 PM | #2 |
Re: Issues with charging system
i had a similar problem, chased a drain for ever, found out that my stereo had shorted internal and was draining the battery down through the memory wire,
something is shorting out and draining?? or did you have the starter checked out, maybe it is pulling too many amps??
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
10-15-2013, 08:54 PM | #3 |
what is your running voltage ?
i dont like 1 wires , 3 wires with remote sensing work better with the sesing wire coming from the fuse block side read this http://madelectrical.com/electrical-tech.shtml |
10-15-2013, 08:57 PM | #4 |
Put a voltmeter on the battery with it at idle and see if it is charging 13.8 v min with at least the heater or headlights on. if it isn't rev it up a bit to like 1,500 and see if the voltage increases, the 1 wire alts need a smaller pulley sometimes or won't charge enough at idle. How old is the battery, have seen many battery's not run the car/truck under load and tries to run on the alt only. The alt is made to replace voltage being used from the battery not supply from itself so if the battery is the problem won't charge properly, easy check is to try another battery for the test if in doubt, then you have 2 to compare. Grounds are important as mentioned, 1 from batt to frame, from frame to engine, from engine to firewall for gauges to work properly. I even add anothe from batt to rad support.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
10-15-2013, 09:14 PM | #5 |
14.2 is a good voltage when running , you should have a ground directly to the block , and another from the battery to the frame
10-15-2013, 10:23 PM | #6 |
Yes, I have grounded from the batt to the frame, and my running voltage is between 13.8 and 14.2 volts while running. I haven't noticed any shorts anywhere, with the brand new wiring system, and my starter is also brand new, bought it yesterday.
10-15-2013, 11:17 PM | #7 |
Sounds like you have covered all your bases but the battery, try another if you have one or can borrow one.
10-15-2013, 11:29 PM | #8 |
Disconnect the ground wire from battery, hook a test light between wire and neg battery post. It should barely glow or not at all if everything is turned off (with exception of radio clock). If it is shining bright, something is on and draining your battery. Find out what's on (pull fuses etc) and fix it.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
10-15-2013, 11:35 PM | #9 |
if one wire why are there two wires hooked to alternator? wire to solenoid from alt looks small. have a fusible link in hot wire to solenoid. why is solenoid on drivers side instead of closer to starter? guess that your battery is on drivers side of truck? install a large style master disconnect near battery - that way you can shut off all power. with battery remote location really need to have one with extra cranking amps.
