10-16-2013, 07:53 PM | #1 |
Roof panel replacement?
Been looking for a good thread that has details for replacing the outer roof panel. Something landed on the cab of my 84 before I got it and it needs fixed. Not sure how hard replacing the panel would be or just trying to see what the bodyman can make of it. The back panel strip that is between the back glass and the upper roof panel is rolled a little bit too.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
10-16-2013, 08:04 PM | #2 |
Re: Roof panel replacement?
Could cut at the top of the windshield seems... My guess is that would be easiest. GO CONVERTIBLE!! Lol. (Wish i had the cash to buy your parts dually btw)
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
10-16-2013, 08:07 PM | #3 | |
Just sold the C&C yesterday. Trying to buy another RC K30 dually pickup.
10-16-2013, 08:19 PM | #4 |
Getting Old; Going Broke
Unless you can find a new roof skin, why even think about it? If you're thinking of trying to put on a used roof skin and you do not consider yourself a fairly talented body man, then start looking for a complete cab to replace yours with. That would be the simplest for you.
If you can locate a new roof skin, then it's a matter of separating the old and putting the new on with a combo of welds and glue. You basically have 3 pinch areas and one seam. Would take a professional body man roughly 2 or 3 days to do it. Would take an amateur anywhere from a week to 10 years.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
10-16-2013, 08:47 PM | #5 |
You can cut the roof off of a nice cab and graft it on yours. I have seen it done a few times. The body shop cut the A and B pillars about 4-6 inches below the roof and the bad cab the same place . Then he set the new roof on and welded around the perimeter , ground it smooth, and you could never tell it had been worked on.
Frank
Born and proudly residing in a Red State ! |
10-16-2013, 11:30 PM | #6 |
I am wanting to avoid putting in a new cab. I am already doing that for my short bed and it is a pain. Not including trying to find a good cab in these parts. I thought I remembered seeing a thread on hear somewhere that showed their process but can't find it now. Anyone have a link or photos of one being done?
10-17-2013, 10:13 AM | #7 | |
plus - this might be a good time to do a mild "top chop". K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-17-2013, 09:27 AM | #8 |
There's a lot of em in the 67-72 pages. I'd just follow what they did. Go slow n do it right.
10-17-2013, 09:59 AM | #9 | |
The guy who bought the K30 parts trucks lives just an hour from you in Williams.
10-17-2013, 09:33 PM | #10 |
Street Rod Restoration
I did this last year, I used the factory pinch line in the rear of the cab, drilled out all the spot welds (you'll need a few of these, I broke a few from Eastwood) Gently cut the corners where the factory braze is located and you can remove the skin. I purchased a flange punch from Harbor Freight to help save time and drill bits. Then You have to do the same with your donor truck. I plug welded the front after grinding all the metal smooth and sprayed with weld through primer to make sure no rust would show up later down the road. I then plug welded the inside holes and tacked all around the back of the cab, removing the factory line where the roof was mated on. All in all...2 weekends, about 15hrs for me off and on.
Follow me on Instagram @ hot_rod_shop |
10-18-2013, 08:44 AM | #11 |
Its really not that hard to do... Check out this link for further details...
http://67-72chevytrucks.com/vboard/s...d.php?t=572601 |
