02 sensor help
I have a harness that came with the flat 4 pin 02 sensor connector. The problem is that its a male connector, also all the 02 sensors I have seen have male connectors too. What am I missing here? The harness came off a 01 chevy truck with a 4l80e trans if that helps. Can I get an coupling or just buy the female connecter? Thanks
Re: 02 sensor help
That's just how they are, mines the same and its a 99. O2 sensors do come with female plugs.
Re: 02 sensor help
Thanks I didn't realize that, yea I found the sensor I think will work bosch 13027 it has the female end.
meowMEOWmeowMEOW
Re: 02 sensor help
I had mine setup for the "all purpose" upstream 02 sensor with heater circuit. The Bosch 13444 runs the square 4 pin connector instead of the model specific style. They are fairly cheap as well, just something to keep in mind if your making your own harness.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: 02 sensor help
I'm going to resurrect this thread to ask a follow up question. My harness guy put the flat four connectors on my harness instead of the stock 4 square ones. (REFERENCE) I don't mind getting new sensors, in fact, its probably a good idea anyway.
So, True or False: The sensors in question, ![]() ![]() |
