Old 10-18-2013, 10:59 AM   #1
boonedogs72
boonedogs72's Avatar
what wheels for repop 66 caps
morning guys im going to buy a set of repop 66 caps from classic industries
http://www.classicindustries.com/196...s/ct26720.html
was wondering what wheels are available new or used in 15x8.
thanks for the help guys
boonedogs72 is offline   Reply With Quote
Old 10-18-2013, 11:07 AM   #2
1963c-10
1963c-10's Avatar
Re: what wells for repop 66 caps
Theres a OEM set on ebay for $129 (not mine).
link:http://www.ebay.com/itm/1960s-CHEVY-...cfcd4f&vxp=mtr
The cap in the top left is the odd ball, but easy enough to find another OEM cap and have a nice OEM set for half the price of repops
Well, was $129, now $149 buy it now....I would not hesitate on these.
1964 Short bed trailer
Old 10-18-2013, 11:15 AM   #3
boonedogs72
Cool thanks! You know what wheels I have to run to fit the caps?
Old 10-18-2013, 11:18 AM   #4
1963c-10
1963c-10's Avatar
Re: what wheels for repop 66 caps
The stock steelies w/the 3 bump nubs...very common wheels. Ill see if I can get a pic for you. You can also use the later style steelies w/the 4 bump nubs.
The blue one is my 4 bump rim, they came on early 70's-early 90's chevy 4x4's, blazers, etc...and will clear disk brakes. The black one below is a standard 3 bump drum brake rim. Used for many years and many gm truck/van applications. Both are 15" and the 3 bumps should be fairly easy to find. Try Perro or some of the other CA parts guys (you can do a forum member search or use the classifieds here for 60-66).
The bumps(nubs) that you see around the center section hold the cabs on. Check out the hubcap thread I pulled back up also, lots of good info there.
Old 10-18-2013, 11:27 AM   #5
wjjeeper
wjjeeper's Avatar
I've got a set of the 4 bump rims that won't clear the calipers of my disc brakes. Need to run a 1/4" spacer.
Out of curiousity what's the widest tire that guys run on the 15x8 rims?
wjjeeper is offline   Reply With Quote
Old 10-18-2013, 11:36 AM   #6
1963c-10
1963c-10's Avatar
Can you post a pic of you rims?
Old 10-18-2013, 11:46 AM   #7
wjjeeper
wjjeeper's Avatar
I'll post a couple pics this evening.
I'm currently running 295s on the rear of my 65 on Blazer rims, but I really want to go with a different look. That's why I've acquired these 4 bump rims.
Old 10-18-2013, 11:38 AM   #8
1963c-10
1963c-10's Avatar
I've seen guys run all the way up to a 295 tire on a 15 x 8, but not on a truck....maybe some others will help on it.
Old 10-18-2013, 11:54 AM   #9
Sharps40
I love this thread...I do the same thing with guns...buy a box of odd caliber ammo cause it's rare or hard to get and then go about tryin to find a gun to shoot it out of!
Kudos on pickin up yer hubcaps before ya find some wheels! I love this place, we're all lots alike!!!
Sharps40 is offline   Reply With Quote
Old 10-18-2013, 12:33 PM   #10
LVPhotos
LVPhotos's Avatar
I have run 295/50 on 8s. But also Blazer had 15x8 running 35x12.5 stock Rallies.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-18-2013, 03:00 PM   #11
wjjeeper
wjjeeper's Avatar
My bad. I just looked and these rims I picked up are 3 bump.
Old 10-18-2013, 03:11 PM   #12
63burban
Chevy addict
265/70 15
63burban is offline   Reply With Quote
Old 10-18-2013, 03:12 PM   #13
boonedogs72
those went quick....
Old 10-19-2013, 10:19 AM   #14
rideblue00
rideblue00's Avatar
http://www.vintagetrailersupply.com/..._p/vts-068.htm
Not sure about these, i was going to buy one and check them out, just havent got around to it yet.
rideblue00 is offline   Reply With Quote
Old 10-19-2013, 02:42 PM   #15
markeb01
Senior Enthusiast
markeb01's Avatar
They seem to be 3 bump wheels. It would be interesting to know if standard hubcaps fit on them.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
