Old 10-18-2013, 12:11 PM   #1
mvitale27
mvitale27's Avatar
56 3600 SBC/4WD Trans Question
Hey guys,
I have a 383 stroker I built from a 73 vette's 350. I am going to do a 4WD conversion on my truck and I already have an np205 transfer case. I will most likely be running Dana 44 in the front and corporate 12 in the rear. 383 will be putting out about 400 hp and 450 ft lbs of torque.
I am looking for a 5-speed manual w/ overdrive. I heard good things about the NV4500 and I know it hooks up with the SBC and np205, but I also believe it is a low-geared slow-shifting truck tranny? Mainly this truck is going to be powerful, the 4WD conversion is only for snowy winters. I need the overdrive for 3 hours of daily highway/country road commuting and I would like a sportier transmission. I was looking for more of something like the Tremec TKO, but I don't believe it will work with the np205.
Any ideas?
1956 Chevy 3600
Matt's 3/4T 4X4 Build
mvitale27 is offline   Reply With Quote
Old 10-18-2013, 12:54 PM   #2
rgunlock
rgunlock's Avatar
Re: 56 3600 SBC/4WD Trans Question
I have a NV4500 I plan to pair up with NP205 on my build, but since it is a long way from running I can't speak to how it will drive. You may get more responses posting in the 4x4 subforum.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 10-18-2013, 02:08 PM   #3
mvitale27
mvitale27's Avatar
Thanks. I will repost over there and see if I have better luck.
1956 Chevy 3600
Old 11-11-2013, 03:36 PM   #4
mvitale27
mvitale27's Avatar
I have decided to go with a TKO 500 trans. I will be using a divorced np205 from a dodge truck. Now my only question is a crossmember for the transmission. The PO must have cut out the old trans crossmember as it is missing from my truck. Anyone know where I can get a bolt-on or weld-on trans crossmember thats compatible with the Tremec transmission?
1956 Chevy 3600
Old 11-11-2013, 10:15 PM   #5
_Ogre
_Ogre's Avatar
make it. x-members are the easiest thing to fabricate.
your going to ba fabricating all sorts of stuff for a build like this.
why buy when you can make?
shop air compressor timer
Old 11-12-2013, 10:54 AM   #6
mvitale27
mvitale27's Avatar
Good advice. I will be doing a bunch of fabrication, I just figure I would see if anything was out there.
1956 Chevy 3600
