10-21-2013, 05:47 PM | #1 |
Trouble codes
Just got my tuned computer from Speartech. I plugged it in and turned the key on, but didn't try to start it. I hooked up the scanner and it said the computer is a 2012, my engine and tranny are a 2013. Also, 4 hard codes popped up:
P0122 P0223 P0315 P2122 Will the year difference be a problem? Should I worry about trying starting it with those codes?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-21-2013, 06:03 PM | #2 |
meowMEOWmeowMEOW
Re: Trouble codes
Wow....just wow....this is the third Pedal response failure thread. I need to start running a national B!tchslap your Tuner campaign.
The first two codes are Pedal Failure/Tb Failure or low circuit voltage. Basically, the tb and pedal aren't communicating with the ecm (since the TAC functions became integral to the ecm). Third one is that it isn't reading the crank sensor or its out of phase. This one should get solved by a CASE learn, or in some cases just a few starts until it can phase the crank and cam sensors (did you pull the vvt off or no?) Fourth one is reduced engine power. This is a tricky bastardo but usually is a symptom not a cause. It usually pops up when there is a random low idle (i.e. stalls itself out), or when there is a random electrical failure or spike. If you clear the codes and try to start, no harm will be done. It MIGHT not want to start with the crank sensor problem tho. The other problems are ancillary, and the engine should be able to idle without input from the pedal. Considering that you got ALL the codes for the dbw system at the same time AND a crank sensor fail....I would say the mismatch in the ecm is causing some confusion. It would be strange for them to all fail at once barring getting struck by lightening.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
10-21-2013, 06:05 PM | #3 |
meowMEOWmeowMEOW
Re: Trouble codes
http://www.ls2.com/boggs/dtcs/DTC%20P2122.htm
I was gonna copy the whole thing but the links don't work when I steal it. This is the "book" procedure on 2122, but I'm pretty sure the other DTC's are on the site as well. I don't know if it will actually help, as the above info takes into account a factory flash on a stock GM vehicle...
10-21-2013, 07:00 PM | #4 |
Re: Trouble codes
The TB activates fully when the pedal is depressed. The computer was tested on another vehicle before being sent to me. I sent John an email and am waiting on a response.
10-21-2013, 09:00 PM | #5 |
meowMEOWmeowMEOW
Re: Trouble codes
ONLY fully, or does it modulate with input? Mismatched parts can still power up, and sometimes even pass the startup check, but the first time you modulate the throttle it can go wide open then close, and stay closed.
10-21-2013, 10:13 PM | #6 |
Re: Trouble codes
It changes the throttle blade position based on pedal position input. I talked to Speartech about the 315 code and he said he deleted that out. Kinda strange as two different code readers showed it as a permanent code and would not clear it (or the pedal codes). On a different topic, what software will I need to flash the TCM to a corvette tune so I can use my paddle shifters?
10-21-2013, 07:42 PM | #7 |
Re: Trouble codes
Reverify pin out on the pedal to the ECM, to the throttle. I was getting similar codes initially, had to repin my pedal, MAF and map sensors. The wiring harness was wired backwards. Wasn't too hard, just had to switch a couple of pins around.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
10-21-2013, 08:26 PM | #8 |
Re: Trouble codes
Was your throttle plate moving when you pushed the pedal? Mine does.
10-21-2013, 08:40 PM | #9 |
Re: Trouble codes
You know, I didn't check that at all. I just rechecked the pins and they were wrong. Didn't you use the pedal off of a c5 corvette? Maybe the voltage sweep is different for some reason? I'm completely guessing here, just brainstorming. I think one brush goes in ascending voltage and the other in descending, or something like that. Make sure your pedal operates the same as the camaro one does.
10-21-2013, 10:23 PM | #10 |
Re: Trouble codes
Rob,
Take my word for it. Take it to a dyno to get tuned. You will be better off in the long run.
10-21-2013, 10:27 PM | #11 |
Re: Trouble codes
I am, but I've got to be able to drive it there .
10-22-2013, 07:04 AM | #12 |
Location: Sunny, Florida, some might call it South Alabama
Re: Trouble codes
What kind of reader are you using to clear the codes? I have two, one that I bought from Advanced(little orange one), and one that my wife bought me from amazon(a cheapy). Oddly enough the cheapy that she bought will clear all codes no matter what they are and the orange one will not clear them. But more than likely you are getting the throttle code because at some point connectivity has been lost between your throttle and the pcm at some point.
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
10-22-2013, 09:20 AM | #13 | |
Re: Trouble codes
10-22-2013, 01:49 PM | #14 |
meowMEOWmeowMEOW
Re: Trouble codes
The last two codes should clear on start , unless thrre actually was a crank sensor problem.
10-22-2013, 03:42 PM | #15 |
Re: Trouble codes
Thanks! I need to top off the fluids and then I'm going to try and fire it up. On another note, what all software is required to flash the TCM?
10-22-2013, 10:04 PM | #16 |
Re: Trouble codes
I fired it up this evening and it would run for a little while and then die. After I would let it sit for a little while, it would the same thing. What fuel pressure should I have? No check engine light, but the same 4 codes still remain.......it did sound sweet while it was running !
10-23-2013, 01:26 AM | #17 |
meowMEOWmeowMEOW
Re: Trouble codes
58psi.
Did you actually clear the codes, or just read them? Clear them, try again, if its the same four that means its getting the same triggers each time. You might need the CASE relearn to get rid of the crank sensor code. As for the others, we still got an electrical gremlin or tune gremlin.
10-23-2013, 10:11 AM | #18 | |
Re: Trouble codes
Instagram.com/p/fypJDAQaP9/#
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-23-2013 at 10:23 AM. |
10-23-2013, 11:59 AM | #19 |
Re: Trouble codes
Rob,
Interesting question about the permanent thing. Before I went to the dyno I kept getting a reoccurring p0300 misfire code. I would clear it, unplug battery overnight, anything I could think of. It would appear clear, but would show up the minute I turned the key, even without truck started. I tore everything apart looking for it. When I went to the dyno he said the code wasn't present, even though my handheld (innova 3130c) showed it present, and permanent. In the manual it doesn't explain the permanent thing either. I'm curious also. Since the tune I haven't had it occur again. Just the other issue. Oh, and if it's not too much trouble, would you post your video? I would love to see it but am not as socially advanced as you. I don't have an Instagram or Facebook acct. that is just more stuff to distract me!! Shawn
10-23-2013, 12:30 PM | #20 |
Truck and auto performance nut
Re: Trouble codes
I had the issue of not knowing what was going on and was using my Aeroforce scanner gauge and a cheap handheld scan tool.While this lets you see some things and clear codes you can't change much, allows for e-fan control and something else.
So...I bought HPTuners...the same program my tuner uses. This allows me to use the scan feature and send it to him, and he sends me back a modified file to install. Makes tunes fairly painless and is teaching me about controlling it myself...for future projects. I can highly recommend this....regardless of what program is involved...LS1Edit, HPTuners, EFILive, etc. HPTuners wasn't too expensive either (my tuner also sells them and gave me a discount)...around $500? Now GM tech II is a different thing altogether.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
10-23-2013, 01:00 PM | #21 | ||
Re: Trouble codes
10-23-2013, 05:04 PM | #22 | |
Re: Trouble codes
http://www.nelsonperformance.com/index.html
10-23-2013, 08:54 PM | #23 | |
Re: Trouble codes
10-24-2013, 08:12 PM | #24 |
Re: Trouble codes
Still getting These Codes?
P0122 P0223 P0315 P2122 And now these... (2) P0300 Multiple misfires, Don't understand 2 of them though. P0174 Lean Bank 1 More info on your engine & mods? John isn't willing to help you? |
10-24-2013, 09:02 PM | #25 |
Re: Trouble codes
Still getting the first 4 codes. Cleared the last 3. He's to busy. 2013 Camaro 6.2/6L80. TVS 1900 Magnacharger. 80lb siemens injectors. I mechanically removed the VVT/AFM. I'm using a 2004+ corvette pedal. Comp Cam with dual valve springs (cam specs are above), 7.4 pushrods. 1 7/8" mid length headers. LS9 map sensor. Rest of motor is stock. It won't idle and less you feather it.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-24-2013 at 09:29 PM. |
