The '79s back under the knife!
New motor this time! Out with the old, in with a fresh 355. I sold the old motor as a running unit, so I'm starting from scratch! Many things needed to be improved upon since the first build, so I'm pretty excited to get it torn apart. I'm open to suggestions on anything, so let me know what you think. So far I've decided on my carb and intake combo, I'm doing the exhaust over again, (got tired of the dump pipes and leaky collectors) and im going with sort of a circle track look for the motor. I've ordered up these parts so far:
-Quickfuel Black Diamond 600cfm carb -Weiand Street Warior intake -Cherry Bomb 3 inch exhaust kit -Summit distributor and 8mm wires -Cheapo circle track valve covers and breathers -AEM Air/fuel gauge (i'll do another write up on this later) -Vac and volt gauge to match the rest of mine As far as the motor goes, its nothing too special (yet ![]() As far as I know, it's got: 882 heads, Its an 010 block, mild cam, gear drive, ARP head bolt kit, and ARP complete engine bolt set. Ill know the rest when i get it torn apart. Everything in it is brand new, its just been sitting for years... Ill keep everything updated as the project goes on. Parts are on their way and Im hoping to get her back on the road in a few weeks. Feel free to pipe in if you've got any suggestions, questions or concerns. I want to do everything right this time!
1976...no...79...Chevy....wait...GMC shortbed 4x4. 5 inch lift on 35s, 355, sm465, daily driver. One day I'll figure out the story in that one. 1957 Chevy long stepper...not sure what I'm doing with that one yet. Awaiting funds I suppose. |
Re: The '79s back under the knife!
Heres the new motor right now, im still gonna tear it apart, put all new gaskets in it and lube it up before I get it running. And i hope to clean up the engine bay a little before it goes in. Its gotten pretty messy in there since i started driving it.
love your garage!!!!!
swap out those regular rocker arms for some roller tips. I rum them to eas up the wear on the valve stems and little less rotating friction
"Buckle up I wanna try somethin!!" "of course it will hold!, I welded it!" 1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint |
Here's old one coming out. It's got a new home in some guys '83 over on the coast. Don't miss it a bit. Crappy cam, crappy heads, crappy carb, leaked like a Ford.
Gotta love that feeling when the big brown truck comes around! I'm like a little kid at Christmas!
Got the motor torn apart and somewhat back together. New gauges are in, still have one empty hole, but whatever.
That's my plan when I get some different heads! I've got a set of roller rockers and stud girdles, but these heads still got the regular press in studs. Gotta save a little more money for some vortecs!
And thanks! I love my shop too! It was just built so this is the first time I've got to use it for a project. The only bummer is we don't have it wired yet, so no power or lights. But when it comes time to put the motor in i'll just kick my dad out of the garage where there's heat and power. ![]()
Where you have your oil and water gauges is where I have a vent. It would make me think your truck was a no a/c model but in your pic below them I see the controls so I'm confused. My truck is a later model. Don't know if the center vent was elsewhere earlier in the product line or not? So what's the story? Also, good on ya with the new engine. Should be sweet. What are your hp goals and what trans are you running?
It's a no a/c model. Those controls are just the heater controls. As far as the motor I'm not expecting a whole lot. Around 300ish. Hopefully I'll have a little more bottom end than my last motor though! Not yet anyway. Eventually I'm getting a bigger cam and some heads to replace my 80's smoggers. As for the trans I'm running an sm465 and a 205. Just bought a new 12 inch ceramic clutch too!
Well....she's done! What do you guys think about the black? I wanted to get rid of all the chrome so this is what I came up with.
![]() Join Date: Jul 2010
look like circle track motor with those breathers ..i like tha all paint no chrome look
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
![]() Join Date: Oct 2006
Looks GREAT!
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Thanks guys!
#15 |
looks good, like the dash clean and simple.
