10-22-2013, 06:42 PM | #1 |
Brake lines
I am wondering if anyone has had this issue before. After installing 2 1/2 inch lowering spindles, and 1 inch lowering springs, I've noticed that my brake lines seem to be too short. Compressing the suspension seems to make it worse. I think I can have lines made, but how much longer should I make them? Does anyone know where I could get some longer ones? Any help would be greatly appreciated.
10-22-2013, 07:00 PM | #2 |
Re: Brake lines
Hard to tell by the picture, are they on the right side? My stock line lines fit fine on the same drop spindles & springs.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 Last edited by Lee H; 10-22-2013 at 07:08 PM. |
10-22-2013, 07:08 PM | #3 |
67-72 parts collector,…
Re: Brake lines
I assume you have a 71-72 front suspension since the steel line connection point is in front of the crossmember.
What brake hoses did you buy?
10-22-2013, 07:29 PM | #4 |
Re: Brake lines
71/72 they are exactly like the ones that were on the stock spindles
10-22-2013, 07:39 PM | #5 |
Re: Brake lines
I don't know any other way I could route them the first pic is the left side second pic is the right side thay just seem to short to me.
10-22-2013, 08:05 PM | #6 |
Re: Brake lines
Do they stretch at full lock or is there still a little slack?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
10-22-2013, 08:32 PM | #7 |
Re: Brake lines
At a full right hand turn there seems to be some slack and on a full left hand turn there is also some slack. It just seems to be when the wheels are straight and I compress the suspension they seem to be tight.
10-22-2013, 08:50 PM | #8 |
Re: Brake lines
Will be watching this thread for sure. My brake hoses seemed really short after minor drop.
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
10-23-2013, 07:42 PM | #9 |
Re: Brake lines
I have used Inline Tube www.inlinetube.com for stainless braided brake lines to replace the rubber brake lines on one of my other vehicles. They can certainly hook you up with whatever length line you need.
10-23-2013, 08:06 PM | #10 |
Re: Brake lines
Those don't look right for sure. I have 2.5 drop spindles and original springs that are sagging more than an inch. My brake lines actually have a long upward loop. They came from POL I believe. Not sure mine are the correct length but they don't bind anywhere. I'd hate to see you hit a speed bump and rip a hole in those lines.
10-23-2013, 08:31 PM | #11 |
Re: Brake lines
Yes its starting to look like I am going to need to get some custom ones made. the thing is these after market ones are actually a little bit shorter than the stock ones. I need to get some made that are a little longer than the the original ones. anyway I need to start looking into having some made for it. thanks for everyone's response.
