Old 10-23-2013, 05:08 PM   #1
Mick65
Brake light problems!
My brake lights are whooping my butt right now. I'm all out of ideas. When my headlights are off the right brake light works just fine but the lefts running light and break light are much more dim. When I turn my headlights on the running light/brake light on the right remains to work just fine but the running light on the left remains dim. When I hit the brakes with the headlights on the light on the left completely goes out. No running light or brake light.
The entire silver housing on the left reads hot when touched with a voltage reader. Would this be a ground problem? If so, why would it only effect one side? There is a factory ground on that side of the truck from the bed to frame. Would replacing this ground help?
Thank you everybody.
Mick65 is offline   Reply With Quote
Old 10-23-2013, 06:05 PM   #2
wjjeeper
wjjeeper's Avatar
Re: Brake light problems!
Run separate grounds from each tail light bucket to your frame. Then check your wiring from the firewall right back to the tail lights for cross feed if that fails.
wjjeeper is offline   Reply With Quote
Old 10-24-2013, 01:10 AM   #3
Mick65
How did you run these grounds from the bucket to frame. Any pictures would be a huge help too. I'm sick of getting pulled over bc of this. Thanks!
Old 10-24-2013, 10:57 AM   #4
Sledheed
Sanded the taillight housing down to bare metal just above the plug. Solder three feet of 14 gauge wire to it. Ran this wire with taillight and turn wire. Drlled hole in box underneath. Trimmed wire to lengh, Crimped and soldered r ring connector to end of wire. Attached to box/frame with small sheet metal screw.
Sledheed is offline   Reply With Quote
Old 10-24-2013, 11:07 AM   #5
wjjeeper
wjjeeper's Avatar
I used self taping screws to mount the wire on the tail light buckets and the frame.....
Follow me on Instagram
http://instagram.com/ryno._b
Old 10-24-2013, 11:25 AM   #6
TJ's Chevy
TJ's Chevy's Avatar
I don't have taillights on mine so lucky me!!! But, like said definitely check the grounds and if it is oem, check for bad housings and stripped covering....Hope you are able to trace it down! Good thing 60's electrical is simple! These newer cars drive me nuts when i pop the hood!
Old 10-24-2013, 11:49 AM   #7
kieth
kieth's Avatar
TO AVOID THESE PROBLEMS WE SOLDERED A GROUND WIRE TO EACH LIGHT HOUSING, THEN PUT ALL THE WIRES IN A PLASTIC LOOM, THEN GROUNDED THE NEW WIRE TO A TERMINAL BLOCK MOUNTED TO THE TRUCK FRAME AT THE REAR. THIS COMMOM GROUNDING POINT ASSURES A GOOD GROUND AND YOU ONLY HAVE TO LOOK AT ONE PLACE IF THINGS ARE NOT WORKING CORRECTLY. WE PUT ANOTHER AT THE FRONT OF THE TRUCK AND GROUNDED THE CAB, AND ALL LIGHTS TO IT. ALL THE LIGHTS ARE A LOT BRIGHTER.....
HERE IS A LINK TO THE GROUNDING BLOCK:
http://www.electricalconnection.com/...ution-main.htm
HERE IS THE BLOCK MOUNTED AT THE REAR OF THE FRAME ON MY 66
http://kieth.smugmug.com/Trucks/66-G...cH2c2&lb=1&s=A
kieth is offline   Reply With Quote
Old 10-23-2013, 08:43 PM   #8
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Check your grounds. You cant have too many grounds.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-23-2013, 09:22 PM   #9
Hx16457
Hx16457's Avatar
If this is all old OEM you will have to trace each wire. Brakes in the insulation on the old wiring might be half of it! The other half is as everyone said...ground everything to the frame...
P.S. we have been there... Good luck
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 10-23-2013, 09:31 PM   #10
Sledheed
I would suggest rewiring from the firewall back. Pretty easy to do. Then u know what u have. I just did this. Used trailer wire. Comes four wire only need three firewall back. Used the white wire for all other shirt runs. When done wrapped every thing in back with electric tape and made sure it was up and out of they way. Any questions let me know. The wire i pulled out was junk. soldered all connection with shrink tube where needed. Put grounds on both tail light housings and the lisence plate lamp. They not only work. They are brighter.
Old 10-23-2013, 09:35 PM   #11
Sledheed
This link was helpful. Good luck
http://67-72chevytrucks.com/vboard/s...d.php?t=312351
Old 10-23-2013, 09:42 PM   #12
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Well everyone has already told you what the problem is....it's the grounds for sure. These trucks are grounding nightmares and everytime I rewire them I always run extra grounds from each light back to the frame. I run new 4 gauge grounds from the battery to the block and back to the frame. I also ground out the front turn siginals again ......My motto is when in doubt run more grounds......lol
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 10-24-2013, 01:08 AM   #13
Mick65
Thanks gentlemen.
Old 10-24-2013, 03:24 PM   #14
donthekawguy
donthekawguy's Avatar
I replaced the two harnesses for the tail lights, replaced the headlight switch and dimmer switch, redid the female ends at the dimmer switch and put grounds on the tail light housings. That fixed all the problems I had.
66 shorty
donthekawguy is offline   Reply With Quote
