Old 10-25-2013, 05:49 PM   #1
w70442
49 chevy 5 window Firebird
Hello,
Working on a 49 5 window. Putting on an 88 s10 frame with 2000 Firebird LS1 and 4l60e trans. I'll add some pics soon as I can.
I bought a wrecked 2000 Formula Firebird so I have all the parts from it to use as needed/wanted.
As most may know, the steering box on the s10 hits the alternator on the ls1. Has anyone out there tried to use a rack and pinion for the steering to replace the s10 steering in order to avoid the interferance with the stock location of the ls1 alternator. I know there are alternator relocation brackets but I'd like to keep the alt down out of the way and out of sight.
I would appreciate any input.I also look forward to sharing what I learn as I go.
Thank you,
Randy
w70442 is offline   Reply With Quote
Old 10-25-2013, 08:56 PM   #2
av8tr33337
av8tr33337's Avatar
Re: 49 chevy 5 window Firebird
I'm subscribed. The the pictures FLY. I'm doing a 51 on a 94 S10 chassis with and 84 Camaro Drive Train.
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 10-26-2013, 03:50 AM   #3
w70442
Hey Bartman,
I got the cab and frame back in Feb of 2013 and have been researching the various swaps online since then. Yours was one of the first ones I followed and saved pics from. Thanks!
Besides the power steering rack and pinion swap, I'm also trying to find out which headers or exhaust manifolds best fit the s10/Firebird LS1 application.
Here's some pics showing what I started with. Not much as far as the cab goes. I may change cabs if I finder a nicer 5 window cab.
Old 10-26-2013, 03:58 AM   #4
w70442
Thanks to you and others, I knew I needed to cut the front 7 inches of the frame off. So I cut them off and welded caps on them.
Then I used Jeffs51's cab mount drawing and cut my cab mounts. I used 4" x 4" 1/4" thick. Probably overkill but that's what my local metal supplier had and better safe than sorry.
Old 10-26-2013, 11:44 AM   #5
ghettoluxury
ghettoluxury's Avatar
I would try to use the rack off of the firebird first. As for manifolds or headers the Trailblazer SS manifolds work the best.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 10-26-2013, 12:07 PM   #6
av8tr33337
av8tr33337's Avatar
I think these might work for your application. These are not my pics, just some I found on the internet. These are headman S10 V8 conversion headers. I picked a pair of them up off of Craigslist for 20 bucks. Mine are in rough shape, but I'm going to use them for a while. The steering shaft passes through them. Not sure if that will work with the rack and pinion but it's just a thought.
av8tr33337
1951 3100 Pickup
Old 10-28-2013, 05:07 AM   #7
w70442
Bartman,
Thanks for the reply and again for you thread. Those headers are for v8's but I am puting an LS1 in mine. The exhaust ports on the LS1 are evenly spaced apart and those have the two center ports next to each other. I dunno, maybe that company makes that style, that the steering shaft goes through, for the LS1 too.
Speaking of headers, what's the concensus out there regarding stainless or silver ceramic coated as far as which ones stay looking good longer?
Old 10-26-2013, 06:02 PM   #8
w70442
Thanks for the reply. I looked at the stainless headers on ebay that are said to be for 2006 Trailblazers and they appear to be the same shape as the ones I have now that were on the 2000 Firebird. These hit the rear lower control arm mount at the collector on the driver side.
What year Trailblazer headers are you referencing? And are you saying that they fit the S10 frame?
Old 10-27-2013, 11:15 PM   #9
w70442
Hey guys,
One step forward, two steps back. The 2000 firebird rack and pinion will not work. Even if I were to have the inner tie rods reworked to mate to the s10 outer tie rods, the steering shaft input itself hits the frame/cradle right at the cradle and the frame fork joint. It not only hits the driver side frame but it also tilts back too much for the steering linkage to clear the cradle. This s10 frame/cradle is way thicker than the thin f-body K member. I've seen where people have used mustang II racks for narrow applications so if I do go the rack and pinion route, I'll look into one of those.
I had originally asked about using the rack because the alternator on the LS1 was hitting the s10 gear steering box. I took the gear box off and lowered the endinge into place and now see that I wouldn't even have room for the rack and pinion steering linkage to come up through there because the alternator completely blocks that whole area.
So now I see why so many guys are relocating their alternators. I would love to keep the alt down out of sight but there's just no way. Live and learn......
Still wondering if anyone has seen any stainless steel headers for the LS1 S10 swap? All I've seen are the black or silver ceramic coated ones.
Old 10-26-2013, 08:52 PM   #10
ghettoluxury
I'm sorry for the confusion. The manifolds work never used the headers.
Old 10-28-2013, 08:40 AM   #11
ghettoluxury
Ceramic coated headers will not change color like stainless and the are much better at removing heat from the engine bay.
Old 11-19-2013, 03:30 AM   #12
w70442
Still moving forward however slowly. I've been moving the engine around in different positions trying to find one that will cause the least amount of trouble.
I need to create some space between the radiator fan and the water pump. From what I've read, I could spend lots of money and convert from the firebird water pump and accessories to a vette water pump and accessories and gain a grand total of 3/4" of space. Anybody do this and have any real workd results regarding how much space is gained and whether it was worth it?
My alternative is to move the radiator forward. There seems to be room behind the factory 49 chevy truck grill but I will either have to lower the radiator to fit under the hood latch/rad support or modify the upper radiator support/hood latch by cutting the upper 3 or 4 inches off the top.
I've already cut my original radiator bracket down as other have done but haven't welded them back together yet. I'm experimenting with flipping them side to side. This would put the channel for the radiator on the front side of the hood latch bracket instead of behind it.
I'll try and get some pics of where I'm at tonight.
Old 11-19-2013, 08:29 AM   #13
alaska gasser
alaska gasser's Avatar
Why not cut your firewall and move the motor backwards? To me that would save a lot of headaches from having to change and move so many things. I used a '98 S10 frame under my daughter's '46 International and had to move the motor back about 2" to sit where I needed it. It was a simple matter of extending the flat steel portion of the frame so the motor mount had a spot to bolt onto.
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude
http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU
alaska gasser is offline   Reply With Quote
Old 11-19-2013, 10:32 AM   #14
ricott
The Camaro/Firebird waterpump is the same part # as the corvette, the belt just rides on the inside portion of the waterpump pully on the Vette, and on the outward side of the waterpump pully on the Firebird. The Harmonic balancer is closer to the block (by 3/4 of an inch) on the vette, and the other accessories are also in by 3/4 of an inch.
I had the same problem on a corvette restomod I'm building (Camaro alternator was in the space where the power rack needed to be. The way I solved this problem was by using the Holley alternator bracket (approximately 160.00 as I recall) set up for the Camaro /Firebird pully spacing. This moves the alternator up like corvette. You will have to buy the corvette power steering pump and reservoir, but you won't have to buy (and change) the Harmonic balancer (and it is a pain!).
ricott is offline   Reply With Quote
Old 11-19-2013, 11:01 AM   #15
w70442
Hi Gasser,
Yeah, I've thought about that and will likely do that to some degree but the "s10 swap" headers I have are limiting the fore and aft placement. I can move it about 2" back or 8" back by putting the down tube on the rear side of the rear lower control arm mount. Unfortunately, 8" back is not an option given what I want to accomplish. I do believe I can bring it back about 2" by cutting and rewelding the driver side header at the collector as well as the down tube so that they point more straight down than they do now. The collector is angled back now and the down tube wants to hit the rear lower control arm mount. The down tube is not installed in the pics.
Here's some pics. The rad bracket clamped to the fender is actually the pass side bracket flipped backward so that the rad channel is toward the front. You can see that if the driver side was mounted on the driver side, the rad channel would be right in line with the bell on the water pump. I like where the front tire is within the wheel well so I can't really move the cab to gain space. If anything, I may need to bring the cab back an inch since the front wheel will go rearward a little as weight is put on the suspension.
By the way gasser, I read through your extended cab thread. I know a lot of thought went into that. I'm guessing you've done similar things before. It was quite impressive the way you assembled bits and pieces into a complete, nice looking cab.
Old 11-19-2013, 06:35 PM   #16
ghettoluxury
You need to move the engine back at least 2 inches. Look at all the space in front of your firewall.
Old 11-20-2013, 01:28 PM   #17
alaska gasser
Originally Posted by w70442 View Post
Hi Gasser,
By the way gasser, I read through your extended cab thread. I'm guessing you've done similar things before. It was quite impressive the way you assembled bits and pieces into a complete, nice looking cab.
I would try and move the motor back to within about 1" of the firewall. I used manifolds on our motor and that made it easier to move. Also, I would move the cab forward about 3/4" or so to shift the wheels a little further back in the wheelwell, but that's just me.
Thanks for the compliments on the truck. This is actually only the second custom build I have tackled.
