10-25-2013, 09:40 PM | #1 |
Steel Wheels
There really is no one section to ask about wheels. Since its for my 65 I'm asking it here.
I was on Ebay and found some steel wheels in a different bolt pattern, since their steel can the be welded up and redrilled for the 8x6.5" bolt pattern? These:http://www.ebay.com/itm/CHEVROLET-GM...544be1&vxp=mtr I've seen both the 17" and 18" fairy cheap, otherwise I can get adapters made for $124.00 per pair.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
10-25-2013, 11:20 PM | #2 |
Re: Steel Wheels
should be same pattern if looking for 8 lug, dodge and earlier ford are too
10-25-2013, 11:24 PM | #3 |
Re: Steel Wheels
my bad saw they where 8x 180mm need to find earlier ones
10-25-2013, 11:26 PM | #4 |
Re: Steel Wheels
ive found alot of steel wheels at local junk yard real cheap just bring your tape measure
10-26-2013, 12:35 AM | #5 |
60-66 Nut
Re: Steel Wheels
No you can't just weld up the original holes and drill new ones......it's not that simple.
10-26-2013, 02:42 AM | #6 |
Re: Steel Wheels
I wouldn't do it myself that would be nuts. Adapters it shall be and still cheaper then buying new rims.
10-26-2013, 03:18 AM | #7 |
Re: Steel Wheels
Make sure they are good billet adapters!!!
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
10-26-2013, 09:45 AM | #8 |
Re: Steel Wheels
I used 88-98 8 lug on my 66 C20.
10-26-2013, 11:10 AM | #9 |
Re: Steel Wheels
I have earlier (cannot remember the years) Ford 8 lug on my 66 C20. They had Ford stamped on them but I ground that off carefully, then had them sandblasted and I painted them. Same exact bolt pattern, but they are lug-centric, not hub-centric, meaning that the lug nuts are what center the wheel, not the hub. The hub hole is about 1/4" or so larger than the Chevy rims, so it's not much of a difference.
Just one of the hundreds of small details I have learned. |
10-26-2013, 07:24 PM | #10 |
Re: Steel Wheels
I know to only buy the good billet adapters. I bought them for my 64 El Camino to use Olds Intrigue wheels on it which are now on my S10. When I was pricing out tires I found the cheapest 16.5 tires were still $163.00 each and are just ugly. That's why I will end up buying the 18's. But Nissan NV wheels are 8 x 6.5" and are 17 x 7.5".
10-26-2013, 09:54 PM | #11 |
Re: Steel Wheels
EARL84 ford wheels will fit a Chevy but Chevy wheels wont fit a ford
