![]() Join Date: Feb 2012
no vacuum
I have a big muther thumper in my 468 big block, I have no vacuum for my power brakes. Anyone have ideas on this problem?
![]() Join Date: Aug 2008
Re: no vacuum
vacuum resevoir or hydro boost power brake booster off newer truck/ aftermarket
Re: no vacuum
You have checked for leaks I assume? Both at the intake and the carb base? How much is none have you put a gauge on it to see where you are? That is kinda rare with the Comp cams stuff.Everything I have ever cammed using their stuff always made a good vac signal. You may have to go to a vac resivoir or a hydroboost. if you don't have a leak. The hydroboost would insure you always have braking ability. Jim
Re: no vacuum
I am sure there is no vacuum leak. I can pull the power booster hose off and it barely changes idle. big mutha thumper has a lot, I mean a lot of duration and overlap.
Re: no vacuum
Too much cam will do that.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
![]() Join Date: Dec 2012
Re: no vacuum
vacuum pump like THIS ONE
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
Re: no vacuum
All the mutha cams have poor vacuum. You will have to use a vacuum pump
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
2WD Jimmy
![]() Join Date: Mar 2005
Re: no vacuum
If you can afford it, go with the Hydroboost. CPP has the setup.
Re: no vacuum
Had the same problem with my ZZ572. Dropped in a Stainless Steel Brake Co. electric vacuum pump and Vac pressure went from 7 to 18 psi. More than enough to run the booster. Pricey though. $325.00 from Jegs,
