Old 10-30-2013, 03:36 AM   #1
881ton
881ton's Avatar
project rust bucket
This is what I started with, 1988 v30 454,sm 465. Truck was complete w/ dump body. cab was in rough shape, the usual rust and rot. I put a fresh battery and some fuel in it and she fired up. It ran pretty well. I drove it around the shop to check the trans , transfer case, and everything worked as it should. Then I started to tear it down.
ROB
881ton is offline   Reply With Quote
Old 10-30-2013, 03:46 AM   #2
881ton
881ton's Avatar
Re: project rust bucket
cab was pretty rough but repairable. New doors, inner & outer rockers, inner & outer cab corners, cowl extensions, floor supports, and floor pans.
ROB
Old 10-30-2013, 03:55 AM   #3
881ton
881ton's Avatar
started cutting away the old floors and rockers.
ROB
Old 10-30-2013, 04:02 AM   #4
881ton
881ton's Avatar
Another shot of the rocker.
ROB
Old 10-30-2013, 04:15 AM   #5
881ton
881ton's Avatar
Trial fitting replacement panels.
ROB
Old 10-30-2013, 04:53 AM   #6
881ton
881ton's Avatar
Passenger side cowl panel rust was extensive. replacement panel only covered the lower portion. the rest had to be fabricated.
ROB
Old 10-30-2013, 06:30 PM   #7
rusty76
rusty76's Avatar
It looks like you've got some good work going on.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-30-2013, 06:47 PM   #8
881ton
881ton's Avatar
Thanks rusty, its been a long project, almost finished.
ROB
Old 10-30-2013, 09:33 PM   #9
ofnaman
ofnaman's Avatar
What are your plans for it? Restore or a mod? Looking good so far.
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 10-31-2013, 03:30 AM   #10
881ton
881ton's Avatar
My plans are to rebuild it and use it for snowplowing. It will be a work truck.
ROB
Old 10-31-2013, 03:32 AM   #11
881ton
881ton's Avatar
cowl extension after repair.
ROB
Old 10-31-2013, 03:50 AM   #12
881ton
881ton's Avatar
More test fitting trying to set the gaps for the door and rocker. Not bad for reproduction parts.
ROB
Old 10-31-2013, 03:53 AM   #13
881ton
881ton's Avatar
cab corner cut off
ROB
Old 11-02-2013, 11:33 PM   #14
bojak
bojak's Avatar
Are you really going to plow snowy, sandy, and salty roads with this truck? Buy a beater with the money you get from selling me this truck. I promise the only salt near it will be on my grits. Looks awesome, great work.
bojak is offline   Reply With Quote
Old 11-03-2013, 05:09 AM   #15
881ton
881ton's Avatar
Thanks guys ! Sorry to say she is going to plow snow and haul a sander. I do commercial snow plowing in the winter. I need to have a good solid truck to do this b/c I cant afford the downtime. I had looked at newer trucks but they were out of my price range. also, for what I would have to spend to fix the problems with them it would not have been cost effective. I will be the only driver this truck has, so she will be treated well. When all is finished this will cost half the price of a new truck and have the look of a classic. Whatever happens to it I can fix it. I assure you this truck won't end up in a scrapyard if I can help it.
ROB
Old 11-03-2013, 06:20 AM   #16
881ton
881ton's Avatar
25 gallon blazer tank installed and sub-frame for dump body.
ROB
Old 11-03-2013, 06:22 AM   #17
881ton
881ton's Avatar
Rugby 2-3 yd dump body ready for paint.
ROB
Old 11-03-2013, 06:26 AM   #18
881ton
881ton's Avatar
dump body and cummins flaps
ROB
Old 11-03-2013, 07:10 AM   #19
Liddy71
Liddy71's Avatar
Job well done looks nice
Liddy71 is offline   Reply With Quote
Old 11-03-2013, 07:12 AM   #20
881ton
881ton's Avatar
Thank you I appreciate it.
ROB
Old 11-03-2013, 07:37 PM   #21
tekin112000
Great build
I hope you are able to enjoy this classic for years
tekin112000 is offline   Reply With Quote
Old 11-03-2013, 09:04 PM   #22
Greenlee
Greenlee's Avatar
Looks great! I agree, cheaper than a new one and a lot cooler truck!
Greenlee is offline   Reply With Quote
Old 11-03-2013, 10:16 PM   #23
Flatlandsurfer
Flatlandsurfer's Avatar
Wow man! Nice build, beautiful truck!
1984 Sierra Classic SWB
1986 Sierra Classic LWB
1987 Silverado LWB
1991 Suburban 2500 454
1993 Sierra Ext. SWB 6.2
2012 Silverado Crew Dirtymax!
Flatlandsurfer is offline   Reply With Quote
Old 11-04-2013, 07:19 AM   #24
madcow75
madcow75's Avatar
Very nice... How long did it take you to build.
madcow75 is offline   Reply With Quote
Old 11-04-2013, 10:37 AM   #25
881ton
881ton's Avatar
Thanks for the feedback, I appreciate it. This project took approx. 3 1/2 yrs to complete. I was only able to work on it in the winter when I am laid off.
It was a lot of fun and a ton of work as most of you know. I would like to do another project specifically, an 86 -91 crewcab v30 pickup. This would also be a cummins swap w/ Allison 1000 trans. This would not be built to plow but a daily driver. If I had to do it again I would try to find a rust free truck to start, because it would save so much time.
ROB
