10-30-2013, 12:38 PM | #1 |
mini starter with old bellhousing
will a bolt to the block mini starter work with the org bell housing? just wondering, as you never know what you are getting with a rebuilt.
1961 chevy K10 my build is------------61K10 build |
10-30-2013, 11:49 PM | #2 |
Re: mini starter with old bellhousing
Mine did, even kinda got the metal covers to fit too.
10-31-2013, 08:45 AM | #3 |
The one I bought did not.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
10-31-2013, 01:42 PM | #4 |
McCoyAZ--why didn't it fit?
10-31-2013, 09:19 PM | #5 |
That's a good question It would not engage the flywheel It wouldn't line up with the teeth for some reason.
I quit messing with it altogether and went with a standard sized hi torque starter.
10-31-2013, 09:25 PM | #6 | |
ron |
11-01-2013, 02:58 PM | #7 |
Ron i have the big 168t flywheel, just wanted to know if when bolted to the block the bell housing wouldn't interfere some way.
11-01-2013, 03:42 PM | #8 | |
sorry can't help you beyond that. no one else had mentioned the 2 sizes of r/gears so i did ron |
11-01-2013, 11:36 PM | #9 |
60-66 Nut
I have never tried a mini starter with the original style bellhousing in these trucks. I do know that the typical block mounted starter will not work with this bellhousing. The starter nose hits inside the bellhousing. Why not just get the correct starter for the bellhousing?
11-02-2013, 12:22 PM | #10 |
thanks Captain thats what i wanted to know, but a mini without the nose should work. do you know of anybody that makes a new org style starter? best rebuilt?
11-02-2013, 03:02 PM | #11 |
The mini starters fit fine with the old truck bell housing on mine. There is nothing on those starters that sticks behind the front plane of the ring gear. I have a Powermaster 9600 on mine and have also temporarily fit a 9000 which is a Hitachi style I believe.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel |
