Old 11-03-2013, 08:59 AM   #1
Jayschevy
Anybody else make a rear slip driveshaft other than CPP?
I have a 71 LWB truck and need a slip driveshaft for my truck. It's the driveshaft that runs from the carrier bearing back to the rear axle. I see that CPP makes one but was wondering if anyone else sell one as well.
Jayschevy is offline   Reply With Quote
Old 11-03-2013, 09:38 AM   #2
bigmac73
bigmac73's Avatar
Re: Anybody else make a rear slip driveshaft other than CPP?
my local drive shaft shop quoted me 700 to upgrade to a 3inch tube, with all new 1350 series joints from tranny yoke to pinion yoke with carrier bearing installed, to include making a slip joint style
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-03-2013, 11:58 AM   #3
jhwkns
Registered Cruiser
jhwkns's Avatar
I had one made for
$125 at a driveline shop here in Vegas.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 11-03-2013, 01:46 PM   #4
mgchevyparts
mgchevyparts's Avatar
Go to these guys for a quality unit: http://www.iedls.com/Driveshafts/Critical-Link.asp
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 11-03-2013, 02:31 PM   #5
Andy4639
Old member
Andy4639's Avatar
Question Re: Anybody else make a rear slip driveshaft other than CPP?
If u don't mind me asking, why do u need the slip drive shaft? Just wondering.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-03-2013, 07:25 PM   #6
Jayschevy
My truck is bagged. The style carrier bearing I'm using require a slip drive shaft between the carrier bearing and rear axle to compensate for the up and down travel of the suspension.
Old 11-03-2013, 08:24 PM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: Anybody else make a rear slip driveshaft other than CPP?
OK just thought I would ask. Mine is a LWB with a static drop with a stock drive shaft. Just wanted to know.
