Old 11-04-2013, 04:59 AM   #1
jrdamien
Definitive Rear End Swap
As always I've scoured this forum, that forum, all the forums! Need a rear end for a '49 - '54 frame.
Does anything swap direct, spring perches, leafs and all? I saw some speculation mid 70's Camaros do but found nobody that had actually done it and had pics.
Suggestions? By this I mean, suggestions of something you've done that worked?
jrdamien is offline   Reply With Quote
Old 11-04-2013, 10:03 AM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Definitive Rear End Swap
There are no direct swaps. All will at least need spring perches relocated, unless you order a new one from a supplier like Currie.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-04-2013, 02:45 PM   #3
_Ogre
_Ogre's Avatar
http://www.chevytrucks.org/tech/ifs&rearend.htm scroll way down
shop air compressor timer
Old 11-04-2013, 05:43 PM   #4
Highsider
Highsider's Avatar
Originally Posted by _Ogre View Post
I bookmarked that for the future.
I was sorta bummed after reading the Ford 9" sucks more power to turn. That is what my '57 TF panel has.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 11-05-2013, 12:36 AM   #5
1project2many
Ahhh... it's a small amount. Nothing to worry about. Keep engine rpm low on the highway and you'll more than make up for it.
1project2many is offline   Reply With Quote
Old 11-05-2013, 09:29 AM   #6
Highsider
Highsider's Avatar
After the deer repairs are complete, I will consider the rear end gear ratio change.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 11-05-2013, 01:20 PM   #7
alaska gasser
alaska gasser's Avatar
When I built my '52 Chev panel, I swapped a Ford Maveric 8" straight in without changing anything.
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude
http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU
alaska gasser is offline   Reply With Quote
