11-06-2013, 07:58 PM | #1 |
4L60E to factory column shift?
Anything special required to mate the factory column shift to the 4L60e? Drive train gets dropped in tomorrow!
Thanks! |
11-06-2013, 08:19 PM | #2 |
Re: 4L60E to factory column shift?
nope... mine works just fine with the stock linkage!
11-06-2013, 08:27 PM | #3 |
Awesome, thanks
11-06-2013, 10:11 PM | #4 |
If you need more room for exhaust, Lokar sells a kit. OBTW, what squadron are you attached to?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-06-2013, 11:09 PM | #5 |
ok cool, thanks for the info! Right now, HM-14...prior VT-10 and HM-15
11-06-2013, 11:19 PM | #6 |
Aircrew or Pilot?
11-07-2013, 06:09 AM | #7 |
I have a few questions regarding the use of stock column shifter. How does the 3 speed shift gate in the column play with the 4 position gear selector in the trans? Are you guys able to pull shifter down to lowest position? Does neutral line up correctly?
04 Yukon XL 2500 w/ Quadrasteer 61 Chevy C60, 261 inline six 86 Chevy C20 2wd, Banks 6.2 05 GMC Sierra 2500hd Duramax |
11-07-2013, 03:36 PM | #8 | |
Rob
11-07-2013, 07:59 AM | #9 |
Pilot
11-07-2013, 08:53 AM | #10 |
When did u go through the HTs? I was an IP in HT18 from 2000-2007.
11-08-2013, 12:06 PM | #11 |
11-08-2013, 12:31 PM | #12 |
Especially in my case....wrenching on a -53 is an exercise in futility
11-07-2013, 10:33 AM | #13 |
4x4
I can get all gears on the 4l60 with the stock shifter. As far as lining up with the pointer, i dont have a pointer on my column yet, so i dont know if it lines up but it does get every gear |
11-07-2013, 10:44 AM | #14 |
Winged Jun 2005 HT18....Maj Courey was my onwing
11-07-2013, 11:19 AM | #15 |
Too funny, I was in HT18 at the time, but was Wing HT Stan Officer. I've known Joe for a long time. Matter of fact, we both currentley work at the TW5 wing building. Small world, . I used to drive my 48 everyday, maybe you remember it.
11-07-2013, 12:31 PM | #16 |
Ha, that's awesome! I do remember that truck....tell Maj Corey that Greg Paules said hello!
11-07-2013, 01:08 PM | #17 |
Will do! You may have seen my suburban parked up here to before I started restoring it...
11-07-2013, 02:55 PM | #18 |
The only problem I had was mentioned above and when I redid my exhaust I didnt get it low enough to start with and my linkage interfered with the pipes. I could not go into low. That is really not necessary since the computer does what it wants to anyway lol. I did fix it but thought about using the Lokar cable it looked much cleaner. There seems to be enough "slop" in the shifter I was never sure by looking at the pointer what gear I was in. I normally just left it in OD and went for it.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
11-07-2013, 06:19 PM | #19 |
I had seen a few years ago a 4 speed plate for the column. So it had the OD spot as well as the others. I recently looked and coldnt find it I am not sure if it went into production.
But Yes neutral lines up so you can start your truck in neutral and park as well as having reverse lights. again sometimes they are a little sloppy but always worked. Dave
11-07-2013, 06:41 PM | #20 | |
11-08-2013, 10:51 AM | #21 |
Thanks Rob, those are pretty cool. I am now running a T56 so I don't need them but maybe somebody else can use these.
My truck has tilt so I know those are different and not sure if those are a direct swap or not. anyway thanks for the link.
11-08-2013, 05:29 PM | #22 |
DHC-7 all the way my friend!
