Tired of my long tube headers!!!!!
Hey Guys, just what to get everyones opinon, when i built my truck bought a set of cheap stainless headers and i mean cheap, well now i want to change them out for shorty headers, looking for comments on which are good and bad and will fit angle plug aluminum heads and also clear everything, i've seen a set of sandersons on here just wondering if there is any more out there,
Thanks for any info |
Re: Tired of my long tube headers!!!!!
why do you want to replace them with shortys? just curious
They where not very good quality and i had to do alot of fitment issues, bending for plugs to clear, motor mount and brake line issue
Shorty headers are almost pointless. Long tubes are where you get your power, so I'd suggest investing in some.
71 K20 64 GMC mud truck |
I had these headers installed when the engine was rebuilt, the only issue I had is that they hit the lower control arm on the passenger side so one pipe had to be heated and bent in slightly to make them work. When I had new exhaust run from the headers back this past Thursday the shop I used recommended 3/4 length headers. Of course this was after a couple of thousand miles on the full length headers and old exhaust.
http://www.summitracing.com/parts/SUM-G9112 |
![]() Join Date: Mar 2012
the Headman headers I bought out of the LMC catalog, fit real nice and bolted right up
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
2WD Jimmy
![]() Join Date: Mar 2005
FWIW... Shorty Headers offer NO performance advantage over cast iron manifolds.
#10 | |
I agree. Also shorties give you more headaches than cast iron manifolds.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. ![]() |
i think i'm gonna go with the 3/4 lenght ones that hedman makes, i want to redo my exhaust anyway
