Old 11-12-2013, 07:45 PM   #1
Jahloha
Jahloha's Avatar
Another Bed Removal Inquiry....
I am going to prep my bed for removal tonight (friends coming tomorrow to help lift) and have a few questions:
I am counting 8 bolts...is that correct?
What electrical wirings do I need to unplug? And where are these located?
I am afraid of getting it ready to pull off, then ripping something up because I didn't know I should have removed it.
Thanks everyone!
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-12-2013, 08:09 PM   #2
swamp rat
swamp rat's Avatar
Re: Another Bed Removal Inquiry....
There is a rear light harness plug at the rear of the frame, unplug it. Then look for any ground straps from the bed to the frame. There will be 2 bolts at every bed support going to the frame, if memory serves it should be 8.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-12-2013, 08:11 PM   #3
Jahloha
Jahloha's Avatar
Swamp_Rat:
So there are no wires running on the cab side of the bed?
I am happy to hear it is simply that one harness..
And glad 8 seems to be the right number of bolts.
-JASON
Old 11-12-2013, 08:20 PM   #4
swamp rat
swamp rat's Avatar
Originally Posted by Jahloha View Post
Swamp_Rat:
All the lighting wires should run down the drivers side, inside of the frame rail to the rear, you will see a big black rubber plug at the rear of the frame, unplug it.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-12-2013, 09:22 PM   #5
swamp rat
swamp rat's Avatar
The only time there is wires running at the cab side (driver front) is if there was ever a camper on the back.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
