Anyone running 70 Series Flowmasters?
Looking to see if anyone has went from 40's to the 70 series.
First a little info on my current setup: 355c.i. RPM aluminum heads, 284 Comp XE cam, full length headers, 2.5" exhaust (no x or h pipe) with FM 40 series dumped in front of the axle. While this setup sounds great to me, I would like to tone it down just a bit. I still want to keep it dumped in front of the axle. Before I spend 300 bucks I wanted to see if anyone had any experience with this swap. All the videos on you tube don't demonstrate the difference in interior drone. And that is the main reason I would like to try something quieter. Thanks for any input.
1970 SWB Build |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Anyone running 70 Series Flowmasters?
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() ![]() Join Date: Sep 2008
I picked my 71 GMC Longhorn from the muffler shop this afternoon. It is a big block with stock manifolds. I had Flowmaster 40's with the exhaust in front of the wheels. Was a little annoying. I had the exhaust run out in the stock location, and retained the Flowmasters. It is quieter in the cab and sounds perfect.
#4 | |
1970 SWB Build |
Have them dump right behind the bumper, so you can't see the pipes, and you get that extra distance from the cab
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
I'm running Delta 50's dumping out behind the rear tires.
They're sort of quiet, but could still be a little quieter. I use to have 40's. I just couldn't stand that drone. |
Well, I went ahead and ordered the 70's. If I can figure out how to post videos, I'll post some comparison videos. I'm anxious to hear them compared to the 40's.
1970 SWB Build |
Subscribed...I also have 40s dumped just before rear axle. Like to hear what yours will should like with the 70s
1970 C10 Short Stepper with 71/72 front clip. |
