11-13-2013, 12:29 AM | #1 |
1971 C20 Static drop.
Looking to drop my 71 c20 but i'm having a hard time finding the parts i need.. I DON'T WANT TO DO A C10 AXLE SWAP! I want to have a dropped 3/4 ton long bed for a bike hauler.
So far I found These for the spindles. Springs Can't find a flip kit for the rear! also don't know how legit the drop spindles or the springs are... ANY help would be rad! |
11-13-2013, 08:42 AM | #2 |
67-72 parts collector,…
Re: 1971 C20 Static drop.
Performance Online also carries C20 drop parts for the 67-72 trucks.
11-13-2013, 09:53 PM | #3 |
Are the rear leafs 2.25 or 2.5"?
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
11-13-2013, 10:47 PM | #4 |
POL sells the front spindles and cut one (or one and a half coils). 14bolt? They dont make flip kits for that. You need to buy new perches and weld them on.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-10-2014, 02:35 PM | #5 |
Hate to bring up an old post but was wondering if spindles from a 1987 c3500 would work on a 1971 C20 suburban?
06-10-2014, 09:09 PM | #6 |
I have a set of drop spindles for a 72 3/4 ton that I'm not using
06-10-2014, 09:52 PM | #7 |
06-10-2014, 10:53 PM | #8 |
They are from early classics. It's the c20 to c10 conversion drop spindle. 2-1/2 drop. Check out there site but I believe it runs standard c10 brakes. Bought my truck with them on and when I went to swap to tubular control arms that's when I found out I have all 3/4 ton suspension. I ended up buying drop 1/2 ton spindles to run the tubular arms.
100 bucks plus the ride and there yours The only thing I'm not sure is the brakes. I have 6 lug so that's why I thought I had 1/2 ton stuff up there. Not sure if you can run the 3/4 ton brakes |
