Engine swap no spark
Im in the middle of an engine swap 305 to 350 on my 84 and haven't made much progress because i'm not getting any spark. I re used my old distributor so everything should of been good. Is it possible that i don't have something hooked up that could cause this. I know my tach wiring is correct and i'm getting power at the distributor. I have the 2 ground wires hooked up to the back of the head is there anything else i need to make sure is hooked up?
Rust is better than rice. ![]() |
Re: Engine swap no spark
Did you find tdc #1 when you put the dizzy in?
You could be out 180 degrees on your timing! |
Did you plug the power wire to the dizzy back up? I accidentally plugged mine into my tach spot and fought that for 2 weeks... Not my brightest moment lol i always take my valve cover off to make sure i'm on tdc
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
the wiring to the distributor is correct. I'm pretty sure the distributor is correct, if it was 180 out wouldn't there still be spark just backfiring and such?
The module must have died; pure coincidence and nothing related to the engine swap.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
