11-13-2013, 09:34 PM | #1 |
c20 to c10
have line on 1964 c10 crossmember and rear from 1963 c10,was wondering if this will bolt up on 1964 3/4 i know the u bolts will be different for rear. not sure about front ,thanks for any replys
11-14-2013, 02:12 AM | #2 |
60-66 Nut
Re: c20 to c10
Both the front and rear will be a direct bolt in swap. If you're going to the work, why not use a '73-'87 front suspension? Then you will have front disc brakes. If you want to stay with 6 lug, you can just change the rotors to the aftermarket 6 lug rotors.
11-16-2013, 08:49 PM | #3 |
Re: c20 to c10
got complete front crossmember with power steering box and and rear for a buck 50
