11-14-2013, 10:42 AM | #1 |
1965 K10 Optional Wider Wheels?
Was their an option for wider wheels on the 1965, K10s. If so what dimensions were they. Again I am learning this model, doing a project with my grandson. We are just starting.
Les |
11-14-2013, 06:11 PM | #2 |
Re: 1965 K10 Optional Wider Wheels?
check with 60 66 he has wider factory tire on his 66
11-14-2013, 06:20 PM | #3 |
Not sure What yr but my 72 Blazer had 8" wide wheels on it.
1964 BBC 402 4x4 |
11-14-2013, 07:50 PM | #4 |
According to the 1965 Chevy truck Data Book, No , not from the factory. Widest available were 5 1/2 inch rims. But Special order, which would have been tricky through your dealer, things could be done. My 66 K20 was able to get the 16.5X8 wheels and is well documented. These are 8 lug rims though. I have a 1963 GMC 4x4 that I put factory Chevy 15x8 rims on. But I believe they are later 1973 on up rims. Heres a few pictures of trucks mentioned.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
11-16-2013, 09:49 PM | #5 |
Thanks for the information. 60-66 and Randy thanks for the suggestion on stock looking wider wheels.
The 1965 Chevy truck model brochure shows a dark colored 4x4 model that appears to have wider wheels/tires. I guess the ad guys can take some liberty with the truckers under these brochures. Do you think they look wider ? 60-66 do the 8" wheels fit good and if you don't mind what size tires are you using. Les |
11-16-2013, 11:35 PM | #6 |
Those are just two-too awesome trucks 60-66!
MusicMan70 1961 GMC Suburban |
11-17-2013, 01:04 AM | #7 |
No problems with OE suspension.
They're 36" 12.50x16's on 9" center fire aftermarket steel rims.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
11-17-2013, 07:42 AM | #8 |
Check The Champ, Demonstrator
The 15 x 8 6 lug could also be found on military vehicles 73 up.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
11-17-2013, 10:29 AM | #9 |
Are the 1973, and up 15x8 6 lug factory wheels pretty much standard back spacing. Therefor any 15x8 non-rally (appearance) wheel will work on 64-66 4x4 K10.
I would use a narrower tire for this rim size to put less stress on steering components and frame where steering box mounts. Les |
11-17-2013, 10:45 AM | #10 |
yes standard back spacing.
11-17-2013, 12:51 PM | #11 |
Not mine/not affiliated and from the CL...do three nubs mean drum brakes only?
http://inlandempire.craigslist.org/pts/4177332605.html
11-17-2013, 01:49 PM | #12 | |
11-17-2013, 01:51 PM | #13 |
11-17-2013, 05:28 PM | #14 |
60-66
Thanks for the close-up pictures. Will help me purchase the correct wheels. Your trucks sure look nice! Les |
