Old 11-17-2013, 11:39 PM   #1
NewType72
NewType72's Avatar
Post Best 60-66 static lowering options
A buddy of mine just picked up a 66 chevy c-10 swb 2wd single cab fleetside pickup. It has a fairly decent base but were looking to lower it substantially, say 3-5 drop with just a static drop would be his goal. Here are its specifics
Truck/trailing arm rear suspension
A-arm front end
Power steering
Power brakes (looking for a big brake conversion not high end though)
V-8 700r4 combo
5 or 6 lug possibly (depending on wheel options)
18-20" staggered wheels (no width yet)
DO NOT want to cut up the bed
Simply looking for the best drop kits, spindles, springs, shocks the works.
She's a blank slate so were just trying to map it out right now.
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 11-17-2013, 11:49 PM   #2
boucher racing
boucher racing's Avatar
Re: Best 60-66 static lowering options
I don't know about best, but "best bang for buck" is what I did to the above truck:
- cut 1 1/2 coil off front springs and removed bump stop bracket (free)
- installed TJ Jeep springs in rear with 2" drop blocks ($100)
It rode great and looked tits.
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 11-17-2013, 11:57 PM   #3
NewType72
NewType72's Avatar
Probably looking to go lower and price isn't terrible in the pocket book just looking for a good ride worth doing. CPP, McGaughys, beltech, can't honk of others right now
- Dylan
(209)-985-7721
Old 11-17-2013, 11:58 PM   #4
american revolution
american revolution's Avatar
What year jeep springs?
american revolution is offline   Reply With Quote
Old 11-18-2013, 09:45 PM   #5
mano
mano's Avatar
That's my truck now. It is the best riding static tk I every had. Shad did a nice job with the susp.
mano is offline   Reply With Quote
Old 11-18-2013, 12:23 AM   #6
Thefojizzle@me.com
Really like that stance! How many inches of drop does cutting that much coil give you? I bought brothers truck 2" front coil drop and 4" rear coil drop. I too wanna go as low as I can go static while retaining a good ride and a level look. I can still return these, so if you guys have a better configuration let me know please! Thanks
Thefojizzle@me.com is offline   Reply With Quote
Old 11-18-2013, 12:32 AM   #7
NEWFISHER
NEWFISHER's Avatar
Here's a good place to start. Read the threads on their builds and PM them if needed. I have used all of the sources you listed on other vehicles. 2 1/2 drop spindles, 3" coil front and a bolt in under bed notch rear with 3" coils a 2" block kit, adjustable pan hard bar and rear shock relocation brackets is a good recipe too. Try Borris at way2lo2 here on the forum. Delmo is also a suspension dealer and a good source.
http://67-72chevytrucks.com/vboard/s...d.php?t=507575
NEWFISHER is offline   Reply With Quote
Old 11-18-2013, 01:37 AM   #8
NewType72
NewType72's Avatar
Awesome I'll definitely have some reading material now to hit the ground running on this project of ours. We should be pulling apart the bed tmrw night thanks brother!
- Dylan
(209)-985-7721
Old 11-18-2013, 02:18 AM   #9
Narxoleptic Customs
We had a guy "step" our front arms -$75. Installed factory 4 cyl s10 coils up front - free from a V8 project we had. Had a guy extend the rear shackles 2" - $50. We r on leafs in the back so we just removed a few of them. CPP notch kit from eBay for $100.
The jeeps are wranglers from 97-06 or the TJ model. Folks on here say u can get them free at a 4x4 shop
Narxoleptic Customs is offline   Reply With Quote
Old 11-18-2013, 07:10 AM   #10
FlowerForwarder
Front and rear springs and blocks
FlowerForwarder is offline   Reply With Quote
Old 11-18-2013, 07:14 AM   #11
FlowerForwarder
Front and Rear springs and blocks
Old 11-18-2013, 01:03 PM   #12
NewType72
NewType72's Avatar
Wow brother that truck sits great do you remember what brand the springs and blocks are?
- Dylan
(209)-985-7721
Old 11-18-2013, 07:38 PM   #13
FlowerForwarder
4in cpp spring in the rear, 2in block and 3in cpp with 1/2 round
Old 11-18-2013, 01:19 PM   #14
theastronaut
theastronaut's Avatar
MalibuKasey did a 5.5/7" drop with spindles, springs, and a C-notch. His is about the lowest I've seen static without getting crazy with suspension/frame mods.
Check out his "Buttercup" build for the full details.
http://67-72chevytrucks.com/vboard/s...ight=buttercup
theastronaut is offline   Reply With Quote
Old 11-18-2013, 06:57 PM   #15
davbowen
davbowen's Avatar
theastronaut : you have any issues with steering with that 5.5 drop. i'm looking at redoing mine to get lower and have the same size tires as buttercup. was looking into 4 or 4.4 drop. just wondering how it workd out for you.
davbowen is offline   Reply With Quote
Old 11-18-2013, 11:38 PM   #16
theastronaut
I've never had any issues with it since its not my truck. Check with MalibuKasey, he owns it. I do know that he drives it on the interstate daily.
Old 11-18-2013, 02:38 PM   #17
NewType72
NewType72's Avatar
That looks awesome they seem to be the overall average at that stage so far. But that would be a perfect stance
- Dylan
(209)-985-7721
Old 11-18-2013, 03:11 PM   #18
65Gregg
65Gregg's Avatar
Mine is 2" springs/2" spindles-front and 3" springs/2" blocks-rear. However it would be lower if I didn't have such tall tires on it. 255-70 fronts 265-70 rears. Mine ride is really comfortable with No Limit rear shock relocation kit.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 11-18-2013, 09:50 PM   #19
sixTsix
good looking truck and a good looking stance, Greg ...i'm surprised I have seen it around as i'm in the Conroe area.
sixTsix is offline   Reply With Quote
Old 11-18-2013, 04:20 PM   #20
NewType72
NewType72's Avatar
That's a great look 65gregg were probably looking to go a bit lower but I'm loving the stance on your lwb pickup
- Dylan
(209)-985-7721
drop, spindle, static, suspension
