Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-19-2013, 08:54 AM   #1
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Swapping to aftermarket EFI
I am going to transfer over to to either the EZ fast system or the holley. I am going to run a return so no issue there. Will want to add the NOS as well.
I have been looking for real world feed back on either and have found a little but nothing that makes me see that one is better than the other. With my little rowdy SBC I was told the fast 2.0 would be a simple deal.
Marv How you been?? TX is...well different
GMR-PERFORMANCE is offline   Reply With Quote
Old 11-19-2013, 10:20 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Swapping to aftermarket EFI
Steve,, life is great in Az,, it's only 80's now and lows in the 50's How can it not be wonderful!!! Oh, well,,, I turn 60 today so other than that... it's all good LOL. Hell that just means I'm officially a dirty old man and can quit hiding behind pretense and get down to business!!!
I have one of the older Holley Commander 950 systems on my litle 327 El Camino. I'm pretty happy with it as a cruiser and mild street car. Just know the injectors and tuneup are EVERYTHING. The new Holley EFI is WAY advanced from this old 950 stuff. And the Dominator ECU is pretty cool (but more geared towards the LS motors) The Avenger and Terminator line is pretty user friendly, but may be limiting for your motor,, just check them out.
FAST as far as I have been involved with, is top drawer,, very racer oriented, but VERY geared towards the "already know what your doing" crowd. I know a couple guys that tried to run small blocks in NMCA/ PSCA EFI class with FAST and just couldn't get as much power as a carb (on the dyno anyways) And these were some of the smartest small-block guys I've ever known. Not saying anything bad about FAST as they are the standard in EFI everyone else is measured against,, as much as MSD is to Ignition, or Holley to carbs,, etc. But for jumping into EFI I would want someone close and handy to lend a hand if I were doing FAST. However,,, I think FAST is the only solution of your going to spray much.
Pretty sure Rick, Shaun and a couple other guys here have ran FAST systems,, I'm sure they will chime in with more.
keep in touch you old buzzard!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 11-19-2013, 09:38 PM   #3
ItsRandy
ItsRandy's Avatar
Happy birthday Marv! I started cutting my age in half...then I'm just a youngster.
ItsRandy is offline   Reply With Quote
Old 11-19-2013, 11:35 PM   #4
BigDan3131
BigDan3131's Avatar
Happy Birthday Marv!
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 11-20-2013, 08:50 AM   #5
GMR-PERFORMANCE
Marv you know I tune EFI for a living so going over to that is not going be a huge off set learning curve for me. However it seems that getting a straight answer out of the company is like asking for free cash.. Salesman that know just enough to get the most basic questions.. YES it works great on a SBC we did this. When you ask about real world set up stuff its a blank look.
Old 11-20-2013, 09:10 AM   #6
darkhorse970
darkhorse970's Avatar
I'm tuning in for future reference, might convert my big block somewhere down the road.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 11-22-2013, 03:33 PM   #7
Super73
Super73's Avatar
Cough cough.. LS.. Cough cough.. I could help you a lot there
BTW, good to see you are alive Steve!!
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-23-2013, 07:08 AM   #8
softballnrd27
Always a work in progress
softballnrd27's Avatar
I 2nd that motion, but I am also partial.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 11-22-2013, 03:36 PM   #9
GMR-PERFORMANCE
LS cough ... hmmm might be the valve springs or you need a looser convertor LMAO
Thanks doing ok the huge change in air density here is crazy baro will be 29.4 then its 30.19 with this storm.. Trucks runs killer then not so much
Old 11-22-2013, 10:57 PM   #10
Super73
Super73's Avatar
Got the valve train sorted out.. New guides, lighter valves and stiffer spring. 7,600rpm hyd roller with no issue.
Unfortunately I lifted the heads last time out. But I bet the verter would be close to correct on the bottle.
With the new baby though, I parked it in the garage, drained the fuel cell and haven't touched it.
Old 12-02-2013, 10:19 AM   #11
GMR-PERFORMANCE
Well It looks like I will be using the Holley system. The Auto tune may not work for my engine in the low RPM range say under 2250 as the amount of overlap in the cam however as a starting point however the pro system is a free down load and supports NOS and manual tuning so I am in. Even as far as total auto tune for the NOS .. That is the goal. Meaning no NOS fuel solenoids at all!!!! This has been done on several of the race cars. Inj size for my set up will go bigger and I will ramp up fuel PSI in the process!!
Will have a very nice QF 750 going up for sale soon
Old 12-02-2013, 02:51 PM   #12
69trk
69trk's Avatar
Im using the holley hp. haven't got it running yet tho.. still need to finish the turbo hotside and cold side...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 12-02-2013, 04:40 PM   #13
GMR-PERFORMANCE
I would be buying the terminator system and then using the HP software to deal with the above normal items like the large over lap and reversion set up for low rpm tuning wise and the NOS system increase fuel PSI on the double stage kit. But for starters I will leave the NOS for last. Get the system to be tuned and then work on the NOS. I do not race this on a regular basis to fast for no cage. Everything local is 1/8 mile and that does not do much for me. So the NOS is a just for fun deal.
Old 12-03-2013, 01:33 PM   #14
Marv D
Marv D's Avatar
Steve,, one of your best resources is going to be the EFI forum over at Chevytalk. Doug Folley (Holley's EFI mastermind) frequents there,, and EFI guru Danny Cabral,, as well as a BUNCH of EFI techies. Having Doug and the braintrust a keyboard away was indespensible when I first started screwing with the 950Commander.
