11-20-2013, 08:22 PM | #1 |
66 step side rear wheel not centered
I want to try to center the rear wheels in the fender of my 66 step side there way off. I lowered the rear 6" and slid the bed forward 3/4" know I'm paying the price.
I think I can cut 2" out between the diff and spring which should get me closer. Has anyone done this? |
11-22-2013, 12:41 AM | #2 |
1961 crewcab
Re: 66 step side rear wheel not centered
looking at this last pic:
what if you used the front ubolt hole as your new back ubolt hole, and then drilled/cut a notch for a new front ubolt hole, and then welded a tube in there for the ubolt to go through?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
11-22-2013, 10:47 AM | #3 |
The center of the step-side wheel well opening is located right around 1.25" further forward than its fleet-side counterpart. Add in the fact that you moved the bed forward another .75" and your 2" calculation should be pretty close.
It's going to take some thought and planning to make sure everything works right after moving the axle forward. Things to keep in mind: -Coil spring location/clearance at the axle pad (2" will put the coil spring pretty close to the axle saddle) -Shock angle/clearance (with the lower shock mounting location being moved forward the angle on the mounting locations might not be ideal). -Trac bar angle/length/clearance I am sure you will run into a couple smaller issues/concerns, but these are the main ones that jump out. Let us know if we can be of any help in finding a solution. I know you have spoken to Dave already, but let us know if you have any more questions. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
