Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-21-2013, 10:11 PM   #1
3v0
73 C-50 questions
I have a 73 C-10 with a van body. The door sill has the GVW info on it. See attachment. Two problems.
1. The GVW is stated as a range 16000-24000 lbs
2. The DOT wants GCVR rather then GVW.
I can drive the truck without a CDL. But if I pull a car trailer with it I maybe in trouble. GCVR must not exceed 26000 for private use in Oklahoma. How does one figure out our find out GCVRs ? Last resort is to talk with the DOT.
Recently another member posted a data plate from his C-50 that listed what parts they used to build it (like axle size etc). Where should I be looking for that.
3v0 is offline   Reply With Quote
Old 11-21-2013, 10:58 PM   #2
mrolds88
Re: 73 C-50 questions
You should have a SPID on the glove box door or on an inner fender. The way I would take your VIN plate is that your truck is designed for a 16000 GVW as built, however it could be configured to 24000 from the factory. What does the title say? It will tell you something. Also it might be better to speak with a DOT guy with the title as opposed to the truck itself.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 11-21-2013, 11:30 PM   #3
C10 - C90 Bill
C10 - C90 Bill's Avatar
Those VIN Plates are a little confusing, but I agree that your truck is a 16,000 GVW, especially seeing that the truck is a C-50. The GCVR is usually listed on most trucks, but as we all can clearly see it is not on that plate for some reason. I would check the SPID and Title as mrolds88 has mentioned.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 11-22-2013, 12:57 PM   #4
3v0
I will check the title the next time I get to the bank.
The truck has not done much in the last 10 years. A fellow bought it in california and used it to move to colorado where it sat for 2 years. I purchased it and used it to move from colorado to oklahoma. I put maybe 1000 miles on it. That was 8 years ago.
I replaced the fuel filter and gas line from the fuel pump to the carb. It runs nice but the brakes do not even pump up.
Old 11-22-2013, 05:19 PM   #5
68panelman
68panelman's Avatar
Did they keep that style in 73?. Pretty sure they changed over to the new square style. Your plate may have been changed?, my 2 cents.
68panelman is offline   Reply With Quote
Old 11-22-2013, 06:09 PM   #6
3v0
Nah that was a brain fart. It is a 72 I do not know why I was typing 73.
Old 08-13-2024, 06:30 PM   #7
3v0
I bought the thing to move from CO to OK about 20 years ago. Have been using it for storage since then.
It was way underpowered in spite of having a Mr GoodWrench 350. Had one really bad run loaded into the wind for 100 miles where it would not go over 40. Changed the fuel filter. No help.
Last time I started it I disconnected the rubber fuel line from the metal line coming out of the carb. It was crimped maybe flowing about 1/2 the fuel. Facepalm!
Never occured to me to check the work of the guy who put in the engine.
Caveat emptor!
