Old 11-24-2013, 01:07 PM   #1
pound41
grease on body mount?
I have a NOS set of rubber I was planning to use on my blazer but have decided to save for my other blazer. I have a poly set I am going to use but heard you should grease them. What kind? How much? and where ?
pound41 is offline   Reply With Quote
Old 11-24-2013, 02:24 PM   #2
Special-Ed
Special-Ed's Avatar
Re: grease on body mount?
Id say lithium would do the trick. I'm not sure how a oil bases grease would chemically react to a poly mount material
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 11-24-2013, 02:26 PM   #3
kwmech
I use a waterproof grease, got a large tube of it from the local boat shop. It is Quick Silver 2-4-C Marine Lube with teflon. I think they use it in some of the outdrive parts
Old 11-24-2013, 02:29 PM   #4
Special-Ed
Special-Ed's Avatar
That's good stuff. It's used for the coupler between motor and out drive
Biggest concern is does it chemically react with the poly mount. The wrong grease can destroy a mount.
Old 11-24-2013, 05:06 PM   #5
Chulisohombre
Chulisohombre's Avatar
You don't need them to move so the only grease would be the bolt and sleeve so if you ever need to take the body off it will still come apart. I left mine dry except those two parts and they don't make noise and have been in almost ten years. I used a normal marine waterproof grease so it stays put and keeps water out. I use the same stuff on wheel bearings and all chassis zero fittings.
Chulisohombre is offline   Reply With Quote
