11-24-2013, 06:40 PM | #1 |
Looking for 1970 Clutch Boot
I'm hunting all the usual vendors for a new clutch rod boot (at the firewall, not the bellhousing) for my '70. I found them for up to '66's but nothing newer. Anybody got a source? Mine's pretty much shot.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
11-24-2013, 06:52 PM | #2 |
Re: Looking for 1970 Clutch Boot
Try posting this on the parts board with a wtb title. You might get more exposure there. Let me know if you find one, so I know not to keep an eye out at the yard
11-24-2013, 07:41 PM | #3 |
Thanks AJ. I wanted a new one- with them being rubber, a used one might not be in much better shape than mine.
11-24-2013, 07:08 PM | #4 |
http://www.classicparts.com/1960-72-.../#.UpKF3-J-uGU
http://www.earlyclassic.com/catalog.aspx drop down to shift and clutch boots http://www.classicheartbeat.com/rubb...atherstrip.htm scroll down
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
11-24-2013, 07:38 PM | #5 | |
11-24-2013, 09:08 PM | #6 |
11-24-2013, 09:33 PM | #7 | |
I might just add the 60-66 one to my order at the Truck Shop and take my chances.
11-24-2013, 09:54 PM | #8 | |
http://www.brotherstrucks.com/prodin...number=CRB0720 |
11-25-2013, 07:53 AM | #9 | |
This is what I have coming from the Truck Shop, its a real random hodgepodge but I have so much of the truck apart it makes sense over here. (except for the key blank- I only have one key for the truck so I need to get another one cut!, I've been meaning to order one for a while now so I threw it in) (67-04703) 67-72 Key Blanks Ignition (60-12411) 60-67 Oil filler tube & cap - Tube (60-129101) 60-72 Bellcrank felt gasket seals (60-13004) 60-72 Clutch fork boot (60-13216) 60-72 Spark plug heat shield - Small block V8, 4 pcs. (63-13405) 63-72 Voltage regulator mounting kit - 6 pcs. (63-13501) 63-72 Alternator wire boot (67-13906) 67-72 Wire gutters under hood (67-10301) 67-72 Radiator mounting pads, without AC, with 3 core standard radiator, 4 pcs. (60-10602) 60-72 Water pump mounting bolt kit, Small block, V8 (60-13003) 60-66 Clutch Rod Rubber Boot (the part I was looking for) I'm going to Classic Muscle this morning and depending on what they have in stock, may be leaving with $500 in parts... Rad support, inner fenders, balancer and a bunch of small parts. I found another bunch of stuff I "need" at Summit Racing. Have to get a clutch while its all apart. On the bright side, I came up with a couple really cool ideas that will really make this truck look cool under the hood when its back together. Nothing groundbreaking but what I think are some really nice touches that will be different from the rest at cruise night while still looking factory (beyond the 60's intake and valve covers). Yep, I HAD to take it apart. Just couldn't leave it alone.
11-25-2013, 12:58 PM | #10 | |
11-24-2013, 10:49 PM | #11 | |
Buying small parts like that sucks. Te shipping isn't bad when you buy a bunch of stuff, but on one small part they rape you.
11-24-2013, 09:43 PM | #12 |
2WD Jimmy
You should call Wes at Classic Heartbeat, that's where I bought mine. He has a lot of other hard to find rubber parts as well.
11-25-2013, 07:40 AM | #13 | |
thanks
11-25-2013, 01:29 PM | #14 |
I had to call Brothers just now to check on a credit they were supposed to give me when I sent something back. While they were on the line, I complained about the catalog situation, and had the guy physically mail one to you (I had your address from that gas pedal I sent you). Interestingly, they had your info in their system already, but it just didn't send the catalog.
11-26-2013, 05:22 AM | #15 | |
