HP estimate...opinion needed.
So have been posting alot on here and got another question thought some one must be good at this. Based off your knowledge of set ups and this truck given my setup whats a ballpark for my hp and tq at the wheels,brakes whatever you choose. I have not run a quarter in it just looking for idea. Dont want to be that guy that says he shot the 16 point buck but come find out i only got 8 lol.
Engine Stock 350 bored to 383 around 8.5 compression Stock heads RV cam or 3/4 cam for you old timers lol long tubes to muffler dumps after cab before rear Rest of info is in sig with anything else not mentioned being stock Transmission turbo 350 assuming stock stall Stock driveshaft 10 bolt 3.73 rear with stock tire If you need more just ask. Otherwise appreciate the help. Also if you guys have some good upgrades let me know i like the old school hot rodding style and thats the style its in. If you guys know good upgrade rockers, also what head combos from other gen small blocks can be used on this. just any good feed back you guys got. Thank you
Project Fast 'n' Loud
72' C10 SWB Fleet, Faux Patina, 383 ci stroker The Page: http://67-72chevytrucks.com/vboard/s...d.php?t=608214 |
I have a radical idea!
Re: HP estimate...opinion needed.
First of all a 350 cannot be bored to a 383. It has to have a totally different crank, special pistons, and be be bored .030" over to acheive 383 cu in.
Secondly a 3/4 cam and a RV are two totally different things. A RV cam is a smooth idling torque cam, and a 3/4 cam is a rough idling, high performance cam that needs way more than 8.5 : 1 CR.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#3 | |
I appreciate feedback. Dont know if you intended it to but reply came across a bit stern. I know a 383 needs but i guess i was assuming that was understood and that i ment cast not forged and the most basic needs for a 383 were met. On the cam i really didnt know i was going off of that based on other threads i read awhile back when looking at what a rv cam generally means. So thanks for clearing that up
#4 | |
If it is a 8.5 : 1 CR 383 with a small RV type cam, I'd agree with mmiddle and say about 300 - 320 HP tops. Should be 400 or little more TQ though. Stock heads really limit airflow on a 383, but the 3.75" stroke makes a lot of torque.
#5 | |
#6 | |
A good set of heads will really wake up a 383, but if you have to be careful about getting the CR too high for pump gas with a 383, and most aftermarket heads have smaller cc chambers than 76cc. If you have dish pistons, you have a lot more options. If you can afford aluminum heads, you can get away with higher CR with pump gas.
![]() Join Date: Jul 2013
Assuming your cam peaks at around 5500-6k and not knowing what heads you have, I would guess maybe 300ish.
If your heads are the crappy "light weights" This will kill HP. This set up with say good Vortecs or doublehumps, roller cam and rockers and HEI dizzy you could be in the 400+ range. With only 8.5 CR I would be inclined to think you have 76cc light weight heads. CID=HP, but crappy heads kill that HP.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#8 | |
It does have HEI dizzy. I believe they are the"light weight" heads you are talking about and i am at peak dead balls on 5500 to 6k.
![]() Join Date: Oct 2013
do not know what you really have in your engine to figure horse power but, 3:73 gears with a turbo 350 and stock (?) tires is too low for trans/engine to function properly. don't go racing with this unless you want to break something
Huh? 3.73's a TH350 is great street/strip set-up.
#11 | |
I do have to agree from what i have seen an learned 3.73's and a turbo 350 is a strong street strip combo. I was always under the understanding a 350/350 combo is the street rodders go to and use to be as common in ford and chevy hot rods as leaves are to trees.
If you're doing a basic 383 setup with stock heads and a mild cam I'd guess around 350ish maybe a little more.
2006 Z06 2013 Cruze |
#13 | |
Thank you. "Ish" is all i need appreciate it.
Anyone else feel free to comment.
#15 |
Got it to cooperate
#16 |
Well that's good news! That is the head I was recommending earlier. The 441, 487, 993 casting are the best of the factory 76cc castings. They are heavy castings unlike the later lightweight castings, and flow comparably to the 1.94/1.50" valve 462, 492, 186, double hump heads and the 041 performance heads. These are decent heads have the potential to make a lot more power. I had a set of ported 441's on a 350 in my '82 Z28 that ran 12.50's on motor at one time.
Here is an excerpt from John Lingefelter's Modfiifying SBC's book: http://books.google.com/books?id=GUC...20flow&f=false I'd put your power level more in the 350 - 360 HP range, depending on what your cam actually is. Can you get those specs from the guy who built it?
#17 | |
204/214 @ .050 .420"/.440 112 lsa i was told intake and exhaust could be as high as 224/234 but i could not find a grind profile to match that without it being custom and this sounded very off the shelf.
#18 | |
If it has this cam, the peak power is made before 5000 RPM, so you are probably a little short of 350 - probably 335 - 340-ish? If it had a cam with 224/234, you'd be looking at at least 350, maybe a little more. A cam with that duration would make power to at least 6000 RPM, where the 204/214 cam will be all done at around 4500 or so. Either way, it should be a very stout engine, and make tons of torque. I have a 383 in my '69 C-30 ramp truck that has the CS-1014 cam, 80's 76cc stock heads, a '65 stock cast iron square flange carb, basic 600 cfm Holley single line 4BBL, and I estimate at around 310 - maybe 320 HP based on a similiar build I read about years ago. This engine makes more power at every RPM range than the 396 that was originally in the truck, and is better on fuel too.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 11-29-2013 at 01:27 AM. |
#19 |
To give you an idea between of the differences in the cams, here are some real dyno tests I dug up comparing the cam in question.
Chevy 350 .030" over, stock 186 heads, 9.73 : 1 CR Performer manifold, 600cfm, 1 5/8" headers CS1014 204/214 @ 050 .420/.443 112 LSA 302 HP @ 4800 RPM 364 TQ @ 3400 RPM CS1013 214/224 @ 050 .443/.465 112 LSA 315 HP @ 5200 RPM 355 TQ @ 3600 As you can see, the extra duration makes a lot of difference in HP numbers, but comes with a loss of torque numbers. Here's another build showing the difference in what you gain with a bigger cam, porting and bigger valves. The 441's are basically the same heads you have, and this is a flat top 383 with 76cc heads that came out to 9.3 : 1 CR. This cam would be a little bigger than you'd want in a daily driver, but you get the idea. Displacement: 383 cu. in. Carburetor: Holley 750 double pumper Heads: GM #441 castings, 76cc chambers, 2.02/1.60 in. valves, pocket ported Intake: Edelbrock Performer Camshaft: Comp Cams 280° Magnum hydraulic, with 280/280° of duration, 230/230° of duration @ 0.050 in. lift, and 0.480/0.480 in. lift Rockers: 1.5:1 Headers: 1 5/8 in. street Pistons: TRW forged Rods: 5.565 in. Crank: cast Comp. Ratio: 9.3:1 MAX HP: 382 @ 5300 MAX Torque: 400 @ 4500
#20 | |
