Old 11-25-2013, 02:25 AM   #1
Vova
Next step
Right now I have drop spindles and bags on the front of my 70'. What else can I do to get it down a little lower? Drop member is not in the budget right now.
Vova is offline   Reply With Quote
Old 11-25-2013, 02:38 AM   #2
tinydb84
tinydb84's Avatar
Re: Next step
Hey from the south bay (Im in West SJ).
There isnt too much you can do if you already did the bags and spindles. You can do a sectioned crossmember or Z the frame.
Both are a bit of work. The crosssmember drop will get you about an inch. The Z can get you 2-4 inches.
David
Instagram: myfabguy
Old 11-25-2013, 02:54 AM   #3
Vova
Re: Next step
Hay neighbor, im in the los gatos mountains off summit road.
I was looking for some kind of an arm modification. Guess I'll need to start saving for porterbuilt.
Old 11-25-2013, 02:58 AM   #4
tinydb84
tinydb84's Avatar
Re: Next step
You can cut out the bottom of the arm to sit the bag lower. I did that for mine. Here is a pic.
Or you can move the ball joint up and box it in really well. Only problem with that is that it makes your LCA even closer to the ground and more likely to get caught up when driving.
David
Instagram: myfabguy
Old 11-25-2013, 03:05 AM   #5
Vova
Re: Next step
How much did you gain?
Old 11-25-2013, 03:23 AM   #6
tinydb84
tinydb84's Avatar
Re: Next step
Dont know yet. The truck is still apart. I am doing a bunch of work then dropping it off at a shop to do a Z.
If your bags are flat on the plate then it would be an inch or so. If you have the cups that lift the bag up then that distance plus an inch.
David
Instagram: myfabguy
Old 11-25-2013, 03:26 AM   #7
Vova
Re: Next step
What shop are you using? Looking for a place to shorten my frame 12" at a reasonable price. Just don't have the time to do it myself.
Old 11-25-2013, 03:33 AM   #8
tinydb84
tinydb84's Avatar
Re: Next step
Way's Customs. AVS recommended them. There is also Outkast Customs that Porterbuilt recommended. Way's quoted me cheaper but it's a cash only place on Eastside. They do a ton of work for the B2C car club around here.
David
Instagram: myfabguy
Old 11-25-2013, 03:44 AM   #9
Vova
Re: Next step
I'll give Ways a call. Saw you review on yelp. Do they not have a web site?
Old 11-26-2013, 01:40 AM   #10
Vova
Re: Next step
I called ways today to see how much they would charge to cut sown my frame. Guy on the phone quoted me $1200. That's just crazy for 4-5 hrs of work.
Old 11-27-2013, 10:10 AM   #11
SCOTI
SCOTI's Avatar
Re: Next step
4-5hrs of work would be a stripped down frame w/nothing in the way. I would say most shops would be charging for a full days labor @ minimum.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-27-2013, 03:00 PM   #12
Vova
Re: Next step
You might be right. However I don't think these guys are $150 hr.
Old 11-27-2013, 04:04 PM   #13
hellbent72
Re: Next step
I would call around to see if you can find a better deal. Any frame work where you are cutting a frame in half will cost sone coin. It may seem simple but to get it right cost some coin.
For 3500 I got my rear frame cut off and back halfed, welded in mustang 2 front crossmember w/ rack and pinion, new trans crossmember, sectioned trailing arm crossmember and tubular upper and lower a arms as well as new trans tunnel. All this was done to lay frame like the porterbuilt extreme trucks. I did not supply a single peice.
hellbent72 is offline   Reply With Quote
Old 11-27-2013, 04:21 PM   #14
SCOTI
SCOTI's Avatar
Re: Next step
(1200/150 = 8)
So, only 8hrs 'labor time' for an entire day?
Two guys working on dismantling; 1 guy doing set-up, squaring, welding, grinding/finish work, & then prob 2 doing the re-assemble. That's $1200 for 15hrs labor (10 for the main guy + 5 for the help when required) or $80hr which isn't out of the ordinary.
They wouldn't be running around in an attempt for finishing in a record amount of time to cut costs. They would most likely have a set procedure they follow that 'works' for them (I don't know the shop, just thinking through how I would do things). Some guys might do it for much cheaper if they have no overhead to worry about or are doing it on the side @ home or something.
You could always do it yourself & save significantly.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-25-2013, 03:47 AM   #15
tinydb84
tinydb84's Avatar
Re: Next step
Neither do. Both are on Facebook though with a lot of customer cars they have done.
David
Instagram: myfabguy
Old 11-26-2013, 02:45 AM   #16
tinydb84
tinydb84's Avatar
Re: Next step
Are you sure they understood you meant the frame only? I was quoted 500 for a Z and that included the steering if I provided the parts. They quoted me 300 to do the 4 link if I did the Z with them. Try Outcast, he quoted me 675 for the Z with no steering work. My engine is out btw.
David
Instagram: myfabguy
Old 11-26-2013, 02:56 AM   #17
Vova
Re: Next step
I couldn't find a number for outcast? Have a Facebook link?
Yes I told him just the frame as I already finished the bed.
Old 11-26-2013, 04:13 AM   #18
tinydb84
tinydb84's Avatar
Re: Next step
Maybe he misunderstood. Anyway here is Outkast https://m.facebook.com/OutkastKustom...tkastKustoms67
David
Instagram: myfabguy
Old 11-26-2013, 04:39 AM   #19
Vova
Re: Next step
Thanks man- I'll give them a call tomorrow.
Old 11-26-2013, 09:30 PM   #20
Vova
Re: Next step
I called him again to double check and he said $1200.
Old 12-03-2013, 03:06 AM   #21
Vova
Re: Next step
Talked to nick and looks like I'll be taking my truck there next week. Seems like they do nice work.
Old 11-27-2013, 04:09 PM   #22
tinydb84
tinydb84's Avatar
Re: Next step
Its seems the prices around here range wildly for stuff. I called Sunnyvale Muffler (they also have a fab shop) and they quoted me $800 for a C notch if I had already removed the bed and supplied the metal.
I guess the guy heard the surprise in my voice because after I hung up we talked some more and he called me right back to discuss it a bit more. After talking a bit he said he could do $400 (which I still think is too high-but whatever).
David
Instagram: myfabguy
Old 11-27-2013, 08:49 PM   #23
tinydb84
tinydb84's Avatar
Re: Next step
There are times when I want to drop my truck off at a shop with a handful of cash (like500-1000) just to keep the project going when I am working tons of hours. Instead both trucks just take up space in my driveway and I try to squeeze an hour or two a week in.
David
Instagram: myfabguy
Old 11-27-2013, 08:52 PM   #24
Vova
Re: Next step
I've been trying to spend a few hours a week in the evening after everyone goes to bed to finish up little things. It keeps me moving forward and motivated.
Old 12-03-2013, 03:07 AM   #25
tinydb84
tinydb84's Avatar
Re: Next step
I have heard nothing but positive things about him. How much was the quote?
David
Instagram: myfabguy
