This seems similar to Jason71K10's problem. I have a 72 C10 with a Dana 44 front end. When in 4wheel drive, both hi and low I think, the front wheel really wobble when I do an extreme left or right turn. Is this normal???
![]() Join Date: Feb 2001
I would say no its not normal.
unless your not on dirt or mud or even snow..The wobble is normal..Pavement doesn't allow the tires to "slip" when you make a sharp turn. Remember you have u-joints on the front axles,Thats what causes it..
They'll eventually brake if you drive on pavement in 4wheel drive ![]() Got Mud? Check out my Blazer
Support The Board |
wobble
Well you have something there, I first noticed it on pavement. I also get it on hard dirt roads which I guess is almost the same as pavement. BTW, I don't generally drive in 4x on dirt roads, I do put it in 4x on my property to climb the hills, and I'm usually still in 4x when I get to my driveway. It's on the hard packed that I notice it. I've have two other 4 wheel drives, (shhhhh, don't tell anyone, they're Fords) and I haven't noticed this near as much. Is it possible this condition can be made more apparent with the u-joints getting old????
It can get worse if they are binding from being old or not greaseable..
As for the F*rds I couldn't tell yeah.. I just know about Dana 44 Chevy.I have broke several.. I now run the Dana 60 up front in my Blazer.. I hope I've helped a little.. Maybe someone else has some other Idea ![]() ![]()
Support The Board |
Not sure how much wobble your talking about, but my Dana 44 does have a noticable wobble on pavement when in 4x4. I've got brand new U-joints so I consider it normal. I just take it out of 4x4 and problem solved.
You can't get out if ya don't get in |
#7 | |
Earlier someone had mentioned something about the Dana 60 not having this problem. Is it unique to the D44? |
