![]() Join Date: Feb 2001
68-70 TH400 kickdown switch
Pink wire to fuse box is cut, the rest looks good. $100 shipped.
JQ
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
![]() Join Date: Jul 2013
Re: 68-70 TH400 kickdown switch
Josh can I pick your brain on a correct kickdown switch for a 70. Did all 70 come with tcs (spark arrest) and use the 4 barrel connector, or did some 70 model not come spark arrest and use this 2 spade connector?
You may be right on that. I've seen some '70's with the different connector and the overdrive switch. I did have an all original 1970 one ton with the 2 plug connector pictured above. However, a one ton would not have had TSC.
Joshua
ttt
