Old 11-27-2013, 05:11 PM   #1
jd21476
jd21476's Avatar
Power windows and Power locks retrofit
Has anyone updated their older manual trucks with power windows and locks. I want to kow if there is a kit out there and if they work well or do I need to hit the salvage yard and get a set from a newer model?
1973 Chevy K20
jd21476 is offline   Reply With Quote
Old 11-27-2013, 07:42 PM   #2
1774btcrew
1774btcrew's Avatar
Re: Power windows and Power locks retrofit
I would stick with the factory set up. It is direct plug in and better quality than most aftermarket set ups.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 11-27-2013, 08:51 PM   #3
Greenlee
Greenlee's Avatar
I did this using the factory parts from another truck. The only surprise I ran into was my cab did not have the holes for the wiring. However, there were dimples already there where you need to drill the holes. Also, I tried to use a wiring harness from a Suburban and the windows didn't work correctly. Use a truck harness.
Greenlee is offline   Reply With Quote
Old 11-27-2013, 09:37 PM   #4
1774btcrew
1774btcrew's Avatar
I have 2dr power harnesses for sale in my posts
Old 11-28-2013, 11:11 AM   #5
blazer2007
I,m doing the same ,but how did you get the gasket riveted on to the door,looks kinda tricky, not much room
blazer2007 is offline   Reply With Quote
Old 11-28-2013, 11:12 AM   #6
blazer2007
sorry meant the cab not the door
Old 11-28-2013, 01:02 PM   #7
1774btcrew
1774btcrew's Avatar
A large part of these trucks use bolts with 10mm heads to mount the gasket to the jamb and door. As I sell a lot of these harnesses I actually see more that are bolted than riveted in
Old 11-27-2013, 10:31 PM   #8
Outlaw87
Outlaw87's Avatar
I would recommend that you just find a donor truck, but if you really want to buy a kit, look at these. I'm not promoting them, never used their switch set up, but i knewthey offered these. you can always call them and ask.
http://www.onepieceproducts.com/cate...x?categoryID=1
Outlaw87 is offline   Reply With Quote
