Old 11-29-2013, 12:14 PM   #1
fs64
88 truck any use as donor for disc swap?
Hello I am a new owner of a 64 and have been reading all the posts on the disc swap topic. From what I think I learned an 88 would NOT have any parts I can use? I promise I will post pics as soon as I get a new camera. Thank you for any assistance
fs64 is offline   Reply With Quote
Old 11-29-2013, 01:14 PM   #2
padresag
Re: 88 truck any use as donor for disc swap?
unless it was an 88 c/cab or suburban.
ron
padresag is offline   Reply With Quote
Old 11-30-2013, 12:45 AM   #3
Captainfab
60-66 Nut
The '88-'98 pickup front spindles, rotors and calipers can be used in a couple of ways, but it is a little more complicated than using the '71-'87 pickup front suspension.
One place you can read about it is in this thread, post #16.
http://www.67-72chevytrucks.com/vboa...d.php?t=367260
Old 12-12-2013, 09:17 PM   #4
fs64
WOW is my head spinning after all the threads on this topic !!!!!!!
Just confirming what I think I understand:
I have available a 1988 1500 5 lug donor....
In order to use the 88 suspension I would need lower control arms from a 3/4 ton 73-87 c-20, correct?
Then I would use the 88 upper arm, 88 spindle and the lower arm from the 3/4 C-20?
Which ball joint for lower?
Then all of the steering linkage will swap over? 88 to my 64?
This would give me 5 lugs on front and 6 on rear. Is there a 6 lug spindle available for the 88?
Power steering / brake booster master too?
Thanks to all responders I know this has topic has been commented on in depth but I have read so many I am only positive that I am unsure for sure!!
Old 12-14-2013, 01:35 AM   #5
Captainfab
60-66 Nut
You're close, but not quite.
You will need a '67-'87 C20 lower control arm. Use your original '64 upper control arm. Use the '88 spindle, rotor and caliper, etc. You will use the ball joints for the '88 spindle. The steering linkage will be a mix of both the '88 and the '64, along with the tierods specified in the thread I linked to. If you want 6 lug front discs, then you will use the light duty C2500 rotors also mentioned in the thread (this is the original idea behind using these parts) You can not use the '88 steering box, but you can use the booster and master cylinder. In fact the '88-'98 boosters are one of the boosters compatable with my booster brackets.
Old 12-14-2013, 09:00 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Have you seen anyone who has successfully completed this swap ? I've read about it a lot of times, but all I've seen is reports of ending up with camber issues that can't be adjusted out enough. Id like to read about a successful completed project.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-13-2013, 11:40 AM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
you might have an 87. I believe they went back to 6 lug in 88 unless it was a Burb and or the other. Get some pics of the suspension, and the truck too.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-14-2013, 12:07 PM   #8
Chevy Fleetside
You can get 6 lug rotors for about $75 each. Most guys like to go with 5 lug for more wheel options.
Old 12-15-2013, 02:04 PM   #9
padresag
what are the benefits of going thru the trouble of doing this swap?
ron
Old 12-15-2013, 02:22 PM   #10
Rich 5150 69
Rich 5150 69's Avatar
ron
Ron I think its a matter of economics, not sure of your area but here in Nor cal it s hard to find 73 to 87 parts without paying thru the nose, this would just open up the door for a lot of newer/cheaper parts.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 12-16-2013, 12:56 AM   #11
Captainfab
60-66 Nut
I like it for the ability to have 6 lug front disc brakes using all factory parts. Plus if you are resourceful it can be done fairly inexpensively.
The other advantage would be for the guys that have a C20 or 30 and don't want to run 8 lug wheels. There are less parts to change to get to 5 or 6 lug.
ron
