1968 C10 Snow Bird
This build is for my cousin's wife. He didn't know what kind of truck but he wanted a truck that was for sure. We decided to go with a C10. This is a great looking truck and easy to get parts for. I started looking on craigslist for a truck and since I live in Arizona it was not hard to find a project truck. Me and my friend drove up to Payson and picked up this sweet ride a 1968 C10. This truck was all original. The bed was even full of snow when we picked her up. The kids thought this was awesome since we don't really get snow in mesa. Once we got it home it wasn't long until we got it running and driving. It did not run very well but it was fun to cruise it up and down the street. We picked this truck up from the original owners grandson. His grandpa bought this truck in 1968 and drove it every day. This truck is an original Arizona truck it worked it whole life in Bagdad Arizona. Now the fun begins give this old girl a new life. I am naming this build Snow Bird since it had a bed full of snow when we brought it to the shop.
Re: 1968 C10 Snow Bird
some pictures of the disassembly
more
Time to tackle the bed. The bed floor on this truck was shot. I didn't realize how bad it was until the snow melted. All the bolts were rusted and pretty much a pain to get out we ended up plasma cutting most of it apart. I never really intended on using the original bed floor anyway.
Once the bed was disassembled it was on to the front end.
I thought I would try and save some money by sanding on the body parts my self. That got old pretty quick even with my big compressor and air sanders this is not something that I enjoy doing. So the parts went to media blast, this was much more enjoyable. I don't even know why I tried you can not compete with media blast. It seems like it is just something I have to remind my self on every build I hate sanding down old paint.
I want one!! lol
Shawn 1972 C10 Custom LWB, 3-speed automatic, 350 bored .060 over, Vortec heads, Crane Energizer 260 H10 Cam My Beater/Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=502044 |
Turn Key makes the install super easy. I helped my friend Install one of their Ecotec motors into his sand rail and it is literally 5 wires and you are up and running.
Are they easier and cheaper than going through GM Performance Parts for their E-Rod set up?
68 C10 lwb, 406 sbc, 700R4 86 K30 srw, 454 bbc, TH400 11 Camaro RS, 217 V6, 6M |
I looked into the E-Rod set up when I was making my decision. It didn't seem like it was much cheaper. I got everything for about 10K that included the trans.
http://www.turnkeyenginesupply.com/ Standard Items on ALL Turn Key Engines: Street Package Includes Flywheel or Flexplate Mass airflow sensor Starter Ceramic coated block hugger headers Complete Accessories Alternator Water Pump Serpentine Belt System Brackets and Tensioners Complete Ignition - 5-Wire Hook-Up Coil packs Spark plugs and wires Delphi ECM with Turn Key calibration Custom marine grade engine wiring harness Uses all OEM connectors Electric fan controls Fuse block and relays Complete Detail Package Engine oil and filter K&N air filter Hardware kit Motor mount bolts Oil temperature sending unit port Water temperature sending unit port Engine covers Cable drive throttle body Installation guide Complete AN Fitted Fuel System EFI fuel pump kit AN fitted fuel rails Pre-filter Post-filter Fuel pressure regulator AN-6 & AN-8 fittings O-rings & crush washers O2 sensors Options: Power steering pump AC compressor Motor Mount Adapter plates 4L60E |
I got some parts from Classic Industries. Got every thing to put together a new bed. I am pretty stoked to put the bed together it will be a night and day difference from the original one.
Media blasting and powder coating is a great way to make old parts look better than new. I have been using the hot coat system that Eastwood sells for some time now. http://www.eastwood.com/dual-voltage...arter-kit.html This is a great product for the the occasional powder coater. I have not found anything that I couldn't powder coat. Used in conjunction with prismatic powders the possibilities are endless.http://www.prismaticpowders.com/ The only thing that limits your capabilities is the size of oven you have.
67-72 parts collector,…
![]() Join Date: Nov 2002
What a great truck build!
Subscribiing to watch this one.
nice
Rust is better than rice. ![]() |
#15 |
Tot Roddin'
High quality build. Nice work!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#16 |
I was able to set the motor and trans in place finally. I got the motor mounts and trans crossmember from cpp. This was super easy, I had it installed in about an hour or less. The adapter plates that I got from Turn Key were right on point also.
#17 |
Subscribed! Looking forward to what you do to this thing!
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
#18 |
I wish I had that kind of space to work in. I like the motor/trans combo. Subscribed!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#19 |
Rusty Nuts
Nice build i see happening and a very nice place to do the work.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
#20 |
Thanks Guys. This is at my home shop. I have been wanting to post some pictures of my shop on the forum, just need to do a quick clean up and snap some photos.
#21 |
I got some pics of me replacing the driver's side cab corner over the weekend. I didn't get any until I started fitting the new panel back on though. But what I did was figured out a line where I wanted to do the repair and used masking tape to create a strait line on the patch panel. Then I used my cut of wheel to cut along the taped edge. I cut just off of the edge a little and used my 90deg die grinder with a roll lock disk to finish it in. "80 grit" That was it for my patch panel. Now on to the cab. I trimmed some material off the bottom of the cab corner that way I could fit the patch panel. Then I used a scribe to mark where I wanted to make the cut when I was happy with where it was sitting. Clecos are a great for fitting and holding panels in place. I made the cut and used some butt welding clamps to tack very thing in place. I also used a 3/8 135 deg split point drill to drill out the spot welds.
#22 |
![]() Join Date: May 2007
Got to be tough working in such a small shop with hardly no access to equipment ( lathe, laser jet ect ) lol nah I'm just jealous. Looks like this build will be done be spring.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! Last edited by duallyjams; 12-23-2013 at 04:19 PM. |
#23 |
That's some clean work. I need to learn to do this.
#24 |
Thank You @hardcore4life
#25 |
Cool build..looks like you are in east mesa...where is the place that you bought your engine and tranny located at?
Tags |
1968 chevy fleetside, 5.3 swap, c10, c10 2wd fleetside |
