Old 12-01-2013, 07:35 PM   #1
Shucks
Shucks's Avatar
Shucks First Build
Hey guys, this is my first truck build/restoration. I'm just a 17 year old kid who wants to be proud of something that hes built. The truck body will be mostly at home work and the motor will be a project in my auto tech class in school, mainly because my teacher knows a motor inside and out and my dad really never got too into that stuff. So, since that I am 17 and may not do things right, hell or even get it done, I still came here so I can get some input from you fellas!
Heres what I got goin on...
The truck was free, its a 1979 Chevy 2wd reg cab Stepside with 75,000 original miles with no motor and transmission. The truck is a 2 owner pickup and sat for a long time. But this truck will get me experience with all the bushings, cab mounts, welding panels, motor and trans installation which I already know the basics... just about everything I want to know.
Todays first process.
Hopefully sandblast the frame before it gets too chilly. If you wonder why I'm starting the frame clean up now, its because I dont have a motor and tranny to work around, so Ill clean the frame in sections, rear first, then the front last. I really want to take the cab off but I'm not sure how to without a cherry picker..
My free 1978 4 bolt 350 and free motor stand. Motor runs but needs rebuilt, Main bearings are probably shot. Its my school project.
Also came with free shorties!
I know I have a handful of stuff to do and its gonna be a slow process. I have a good paying job at John Deere so I dont plan on running out of cash, unless I get fired and Im trying to stop chasing girls around so I dont have to pay for movie tickets
So far I havent payed for anything! So I cant complain too much at this point...
Shucks is offline   Reply With Quote
Old 12-01-2013, 07:53 PM   #2
muffintop
Re: Shucks First Build
going to drop or raise the truck?
muffintop is offline   Reply With Quote
Old 12-01-2013, 07:57 PM   #3
Shucks
Shucks's Avatar
Here's how I want my stance.
Old 12-01-2013, 08:10 PM   #4
StarDust
StarDust's Avatar
im guessing a 3/5 drop?
edit:4/6 lol
StarDust is offline   Reply With Quote
Old 12-01-2013, 08:25 PM   #5
TheBlueBomber
TheBlueBomber's Avatar
Sweet truck man. Got to love '79s. Almost done preparing for my motor build. Should be ready to yank it out in the next 1-2 weeks.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 12-01-2013, 08:59 PM   #6
Shucks
Shucks's Avatar
The 4/6 stance is what I'm looking at! Haven't gotten too serious on my search yet, still looking for the right one, All I know is, I just want to go as low as I can without having to run bags. Cant afford those...
Old 12-01-2013, 11:12 PM   #7
StarDust
StarDust's Avatar
you can go as low as you want without bags just that you wont be able get back up there's a guy in houston 7/10 with no bags lol
i second the 4/6 though nice stance
Old 12-02-2013, 12:07 AM   #8
TheBlueBomber
That is insane...
Austin
Old 12-02-2013, 07:57 PM   #9
Shucks
Shucks's Avatar
Well I started the tear down in class today. So far everything looks pretty decent. Teacher was impressed that this motor was free for how clean it is...
Not too bad, the crap sitting inside came from the intake when I pulled it off.
Rockers dont look too nasty.
This is basically the only 2 pistons covered in carbon, its been burning some oil.
Cylinders are actually pretty good, the ones covered in carbon have smooth walls also.
Don't mind the coolant coming from the holes, I flipped it over just a little to fast and didn't realize there was still coolant in the motor, the oil was drained so I figured the guy I bought it from got that out as well.. Oh well, I'm just too anxious to get it done...
Now, the washer/bearing thing not sure what its called, that sits between the nut and the rocker would get stuck about 3/4 of the way up the stud. This happened to 2 of the rockers and they both were the ones that were on top of the carbon covered piston. Does that mean anything at all?
Old 12-09-2013, 05:38 PM   #10
aggie91
I'm just glad to be here!
aggie91's Avatar
First of all, your truck looks like a good starting point for you. It will be a great learning experience for you and something that you will enjoy and hat at the same time. LOL.
...Now, the washer/bearing thing not sure what its called, that sits between the nut and the rocker would get stuck about 3/4 of the way up the stud. This happened to 2 of the rockers and they both were the ones that were on top of the carbon covered piston. Does that mean anything at all?
Most likely it really only means that those 2 cylinders where using oil and it was just some build up on the threads/stud that kept the pivot ball from coming off easily. I had a few before that needed a little effort to get off, but no real damage to the engine.
Enjoy it! I'm guessing your a Junior in HS, so do you plan to have it "finished" for your Senior Year?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-02-2013, 10:38 PM   #11
77ChevySharkBite
77ChevySharkBite's Avatar
Got a sweet looking project there man going to look sharp!! Good luck!!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 12-03-2013, 08:07 PM   #12
Shucks
Shucks's Avatar
So today I learned why the motor was free...
Started tearing into the block.
My 3rd cylinder had a spun bearing.
This is why I hate that its winter and I dont have a place to work on the truck. Its already dark by the time I head home...
Anyway.. I'm probably getting a new crank just because it cut so deep. Anyone have a recommended cheap and solid crank?
Old 12-03-2013, 11:58 PM   #13
nekkidhillbilly
no but..............i figured that speedo would be at higher number than that lol. you should paint like it is when you get done.
nekkidhillbilly is offline   Reply With Quote
Old 12-04-2013, 10:30 AM   #14
truckfan
truckfan's Avatar
another local will lurk
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 12-07-2013, 06:20 PM   #15
Shucks
Shucks's Avatar
Tiny update
Block is now bare and fresh from the washer... Going to the machine shop Monday for new cam bearings, rods and a head job.
My poor sandblasting job with the schools blaster. My frame will turn out better...
hopefully invest in some billet pulleys in the future. This'll do for now!
And this is basically as much work as I can do out in this insanely cold weather, and I even dressed like poor Randy on The Christmas Story
Old 12-09-2013, 02:37 PM   #16
TheBlueBomber
Yall get hit by that winter storm weather? By the time it hit the east coast, all the excitement was virginia and up. Getting work done on my '79
Austin
Old 12-09-2013, 03:13 PM   #17
Shucks
Shucks's Avatar
Well it was intended to hit us but just disappeared when it got to my city... A lot of Kansas got hit but not me.
Your 79 is looking good, I peak into that build every now and then.
Old 01-05-2014, 09:19 PM   #18
Shucks
Shucks's Avatar
Okay I really don't have an update other than my motor is back from the machine shop. But I have more of a question.
My question is, in what steps should I do the body and frame? I get focused on suspension parts then I remember I have rust I need to patch up on the cab, then I worry about body work. Then I get focused on what to paint the frame with then I remember I haven't done anything about the suspension, ect.... Should I patch the rust then remove the cab to be ready for paint? Or should I be worried about getting the truck driving and safe on the road first? I just want some advice is all.
Old 01-06-2014, 04:42 PM   #19
Squareforceone
Squareforceone's Avatar
If i were you i'd get a dual plane intake instead.. Do some research on dual vs single plane intakes. Single is good for the drag strip at higher rpms not so much on the lower end of things on the street.
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 01-09-2014, 10:06 PM   #20
Shucks
Shucks's Avatar
I found a shortbed for sale for $500. Are these a direct replacement for a Stepside or does some work need to be done? Also is this a good price? Because not often do you come across shortbeds separate from the truck in good shape. No rust, and is in primer because the guy has done patch work to the bed. I really want to know because I'd like to ditch the stepside.
Old 01-09-2014, 10:37 PM   #21
TheBlueBomber
Haven't done it myself but shouldn't be too hard. Might need to move the gas tank and install a harness for the taillights among other things.
Austin
Old 01-09-2014, 10:49 PM   #22
bigblock73
yeller
bigblock73's Avatar
Nice project, good work so far.
If I were you, I would do the following...
Finish them engine rebuild, get the truck running and driving. Inspect/rebuild the suspension (perhaps drop it at this time), cheap tires/wheels, clean up the interior...and drive it!
I would put the body back together, and keep it a stepside. Enjoy it for a while, then start doing bodywork as you drive it.
Start tearing it apart, and you will likely have it apart for a while, because restos can gt expensive quick....plus you have school to contend with, which is more important.
bigblock73 is offline   Reply With Quote
Old 01-09-2014, 11:01 PM   #23
Shucks
Shucks's Avatar
You're right. After I posted that and sat and waited I thought of the exact same thing. I get caught up in looking at guys trucks on the forum all torn apart and once its done, they drive it for the first time after a few years...
Thanks for the reply.
The motor is going back together right now (super excited), I found a 700r4 to bolt up to it and then I need to find a new ignition, I bought it without keys...
Old 01-09-2014, 11:47 PM   #24
Cape Codder
Cape Codder's Avatar
A lock cylinder with keys shouldn't be much more that 20.00. It's not that difficult to install.
Cape Codder is offline   Reply With Quote
Old 01-10-2014, 03:11 AM   #25
TheBlueBomber
Bigblock73 is right. When I was 16 I bought a 79 K5 (which started my square body addiction) and I started tearing into anything and everything. I got so caught up in doing multiple projects that it just sat for a while and I lost interest. I learned from my mistakes and am a lot more calculated in the projects that I do. I'm still learning myself after all these years. Make sure you have fun with it and enjoy every bit of it.
Austin
