olds rocket powered blazer
ive wanted to go big block in my blazer for a while.. but i also wanted to be different from every other truck with a small block chev, big block chev, or ls, nothing against them! i just want to be the odd ball... so i found a guy who sold me a 455 with a th400 tranny running for 600.
![]() ![]() ![]() this is the truck, and the small block i will be replacing, its a 350 with 10.25:1 comp., vortec heads, performer rpm air gap manifold, headman headers, cam.. alot! it chugs along pretty good! but there's no replacement for displacement ![]() ![]() heres the beast! out of an 76 delta 88, smogger year but should be alright.
Tyler ------------------------------------------------------ 1980 2wd blazer 1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276 1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784 |
Re: olds rocket powered blazer
Sounds good...good luck with it !
thanks alot! so i got the engine on a stand tonight and started by pulling the intake and valve covers.
![]() quite a build up of sludge in the lifter bank, and rocker arms.. ![]() i dont think it too much though... im gonna say that anyway ![]()
Damn, those are dirty. So what are the build plans for the 455?
68 C10 lwb, 406 sbc, 700R4 86 K30 srw, 454 bbc, TH400 11 Camaro RS, 217 V6, 6M |
I'm not going to do to much, rings and bearings, oil pump, a more aggressive cam, timing chain, replace the smogger "j" heads with better flowing pre 71 heads, aluminum intake, carb... Nothing to crazy, just a budget big block.
That will be cool. I've always been a fan of big block grunt.
kool
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
![]() ![]() ![]() which usually wouldn't be a huge deal, just buy a new set, or find a uncracketed set from the wrecker.... well the cheapest i could find a new set was 300 off ebay, and i looked at three cars at the wrecker, and all three had a cracked left manifold in the same place mine did! so i can get a right one, but not a left! so im either going to braze the set i have, i know its not the greatest, but it'll work!!... or instead of spending the 300 on new manifolds, ill spend about the same money on a set of headers for a A body car, like a cutlass or 442 and do some modifying.
if you want it run like a 70 you will a higher comp ratio. idk on olds but im sure its the same on a stage 1 you can either change to 70 pistons or shave the heads some. do you have an od in the blazer or th350?
68-70 455 were more powerful engines, they all had around 10:1 comp, and better heads... i knoe mines a real smogger, ideally i would like to freshen up a pre 71.. but theyre not around as much anymore... and i converted my truck to a 700r4 from the stock 400, haha and now im going back to the 400.
subbed, im hopping to do a quick 454 freshen up myself.
Thanks! Good luck with your build
so i pulled the heads today, all the cylinders don't seem to be damaged or scored.
![]() http://rs1240.pbsrc.com/albums/gg482...rq.jpg~320x480 alot of carbon build up, and the water jackets are a little rusty. overall its not to bad though
![]() ![]() alot of carbon build up, and the water jackets are a little rusty. overall its not to bad though
#15 |
![]() Join Date: Nov 2010
Good looking blazer, bet its going to be a fun truck
#16 |
merry Christmas!! my dad was kind enough to get me rings, bearings, oil pump, timing chain and a gasket set. should have a good start to my build now!
#17 |
picked up some seats at the junk yard today, theyre out of 2005ish mazda 3, i like the look of them.
#18 |
on the cluster in my truck, the speedo and fuel gauge where always the only two that worked, my temp.,oil pressure, and amp, never worked since ive had the truck, eventually i want to go all aftermarket gauges. for now im just doing the three.
this is what i started with: ![]() from there i cut out a piece of tin to cover where the factory gauges go: ![]() ![]() then with some measurements to line up with the original holes, then i used a holesaw in the drill press to cut out the three holes: ![]() ![]() then i had to cut out the original guage holes to make room for the new ones and bolted/glued my tin overlay: ![]() and this is what i came up with: ![]() its not completely done yet, im going to fiberglass the back to add some reinforcement and a couple other little things.
#19 |
picked up a few things over this week,
![]() i picked up a set of boss 338 20" wheels for my blazer ![]() also i got pretty lucky and found a 1980 chevy half ton with a olds 350 Diesel at the auto wrecker, my 455 should just drop in there now
#20 |
also, its hard to see in the picture, but the rubber mounts are brand new
#22 |
well i picked up some good used tires from my manager, who has a 68 swb, and the weathers looking good for the weekend, so i should be pulling it out of storage and stating to put it together.
#23 |
had a little fitment issue with the boss 338s. had to take a little off my hubs, they work great now tho!
![]() ![]() ![]() i was told boss fixed this problem... but guess not for me! i also started on putting in the seats from the mazda 3, i think they look sharp! ![]() ![]() they should look alot better than the ripped/brown plad ones, with sun faded walmart covers! ![]() next up i want to throw in a set of 2" drop springs, and 2" shackles, to turn my 3-5 drop, to a 5-7
#24 |
this weekend i was pretty busy, cut a coil from my front springs, with mt 3" spindles giving me a total of 5" of drop in the front:
![]() ![]() ![]() to lower the back im going to remove the over load, and one leaf, the thickness of them alone is 3/4". so i should be at least get 2" out of them. ![]() ![]() i ended up tourching the rusty- crusty u bolts... other than that i took all the leafs apart and painted them. im going to see if i can buy new u bolts tomorrow and put it all back together for my 5-7 drop.
#25 |
![]() also picked up some fancy lug nuts for the 338s
