62 With Novak Hyd Clutch Header Question.
I know this appears to be just another header question, but I have searched the forum high and low for someone running a 350 with the Novak hydraulic clutch and headers.
Anyone out there? If not, do any of you 60-62 guys have any suggestions for a good set of headers that will clear pretty well? Thanks
62 GMC LWB Stepside (Project) 95 S-10 350 Conversion 68 Camero 07 Harley Heritage 73 CB 750 Bobber XS 650 Bobber |
Re: 62 With Novak Hyd Clutch Header Question.
Check out Markeb01....he has a sbc w/novak kit. Shouldn't be a clearance issue as the novak conversion sits as high as the clutch fork. Have mocked mine up on the BBC and no clearance issues there either. Mark has a build thread in the "60-66 thread " section. You should be able to reach him there or PM for a response.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
![]() Join Date: Aug 2012
Mark is running the rams horn exhaust manifolds with his Novak setup, any of the block hugger type headers that come out close to the same should fit also.
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
Senior Enthusiast
Yes I didn't respond as I'm running stock ram manifolds. One thing I can offer is how nice the Novak setup works. I've had mine in place since 2005 and never a bit of trouble or maintenance required.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
60-66 Nut
As I said in our last email the Hedman #69260 will definitely fit with the hydraulic conversion, but depending on your engine, those may not be the best from a performance standpoint. A better performing header would be the Hedman #69090, but I just can't tell from pictures if they will clear the slave cylinder. I do have a set of the 69090's that I can bolt up to an engine and see if I can get a couple measurements to help to determine fitment.
http://www.summitracing.com/parts/hed-69090/overview/ http://www.summitracing.com/parts/hed-69260/overview/
