Old 12-03-2013, 06:02 AM   #1
gmc 2500 4x4
separating sm465 from t221 transfer case
im wanting to separate my 465 from the t/case. my book tells me just unbolt and just slide the t/c back. i want to ask here first if indeed thats all it takes? i need to seal up the front and rear adapter. thanx, paul
gmc 2500 4x4 is offline   Reply With Quote
Old 12-03-2013, 11:34 AM   #2
snj8198
snj8198's Avatar
Re: separating sm465 from t221 transfer case
yup, that's it. now would be a good time to check the wear on the trans/t-case output and input shafts and the coupler.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 12-03-2013, 06:13 PM   #3
gmc 2500 4x4
thanx!!
Old 12-04-2013, 12:29 AM   #4
jbclassix
Junk Yartist
jbclassix's Avatar
There is a cover on the side with 2 bolts. You have to remove that cover to access the 2 adapter bolts INSIDE the adapter. Hey, by the way, I'm a feet dragger.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 12-04-2013, 06:24 AM   #5
gmc 2500 4x4
-Jeremy, my book tells me this, thanx....let me know bout them parts lol
Old 12-04-2013, 06:11 PM   #6
gmc 2500 4x4
snj8198, all looks good!
Old 12-04-2013, 08:30 PM   #7
snj8198
snj8198's Avatar
good to hear! you're on your way.
stay warm out there. it ain't here.
Steve
Old 12-08-2013, 03:48 PM   #8
gmc 2500 4x4
i did find a few places with rebuild kits for this t/c, 1 place 315.00, another 249.00. good grief.
Old 12-25-2013, 08:52 AM   #9
gmc 2500 4x4
anyone have a spare coupler let me know, everything else looked fine
Old 01-07-2014, 08:15 AM   #10
1969K10
1969K10's Avatar
IIRC, a coupler from a 205 will fit. But if the coupler looks bad, then the input or output shaft is also bad.
But yeah rebuild kits for these are not cheap. It cost me less to swap over to a 205, but i miss my old 221.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-07-2014, 10:55 AM   #11
CUSTOM/10
CUSTOM/10's Avatar
I have a nice coupler from a NP205 / SM465, but it's a little longer. I believe it's about 4-1/4". It's a GM part I bought from a dealership, but it got very little use. If this will work for you, let me know.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
