![]() Join Date: Jan 2012
87 chevy stepside gas tank filler neck
already listed in parts section, thought someone might see here. i purchased gm 14041212 fuel fill hose from gm. fixing the previous owners attempt at a gas tank. mounting a factory 16 gallon tank on pass side. need the fuel filler metal neck for a step side. will buy the whole tank/hose/neck if i have to. anyone? any suggestions or help would be appriciated. thank you.
Re: 87 chevy stepside gas tank filler neck
6' or 8' stepside box? And I'm not positive but each side neck is the same I think?
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
anyone? need this asap. thank you.
U have to make urself or Get a exhaust co to bend up metal for the majority like a J
and use pre bent gas hose at each ends to make the rest fit the no loner sell for stepside I |
LMC lists a filler neck, does it not work? I have a 84 Stepside and need to replace it, don't wanna order if it won't work. Thanks.
unfortunately, no one sells the stepside filler neck.
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop |
Hmm bummer guess I'll have to manufacture on or try to solder original. Thanks.
