Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-06-2013, 01:49 AM   #1
68c10owner
68c10owner's Avatar
pump gas 454 combos?
I`m still searching for a 73-75 c-10 to make into a street/strip hot rod but I`m interested in hearing what kind of engine set ups you guys are running to push these heavy trucks to the low 12`s-high 11`s. Not going to cage it so can`t go faster than 11.49 and must run on junk California 91 pump gas. I`m planning to do a flat top 454 with closed chamber ovals. Compression should be around 9.5:1. Heads are at the machine shop now and are 390 casting closed chamber ovals that are listed at 96cc chambers. They are getting 2.19/1.88 valves and just some mild porting. Plan to keep the rpm range at no more than around 6200rpms. So what are you guys running?
Anthony
68c10owner is offline   Reply With Quote
Old 12-06-2013, 02:21 PM   #2
dinnut
dinnut's Avatar
Re: pump gas 454 combos?
My current setup Will 12.0-12.1 @109 on 93 octane and a 325 drag radial with a 3.55 gear through mufflers. Put some 104 octane race gas in it and itll go 11.9x@111.
454 chevy .70over
Srp small dome forged pistons. 10:1 with a 114 cc head
781 oval ports with 2.19/1.88 valves exhaust bowls have been opened up.
Comp xe284 240/246@.50 .57x/.58x lift
Rpm air gap
Holley 850
4100 freakshow. Transking th400.
Gearing is not optimal for tire size and end of track rpm.
1.70 60' on motor
Dyno'd 525@5600hp and 560tq@4400 on an engine dyno
longbed truck @ 4000 w/ driver
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-06-2013, 02:33 PM   #3
68c10owner
68c10owner's Avatar
454 chevy .70over
Rpm air gap
Holley 850
1.70 60' on motor
Sounds like a strong runner. I think my 11" 2800-3000 stall is going to hurt me but I can get it going with that and change it out later. I planned on running a 28" tire with 4.11 gears. Figured I`d need the gear to help get the heavy truck rolling.
Anthony
Old 12-07-2013, 01:40 AM   #4
dinnut
dinnut's Avatar
My plan is to change to the 315/60/15 Et street radials and put it on a 12 inch wheel. .gonna go with a 4.11 gear as we'll but with a 30" tire still have decent rpms when I spray. I've had better luck with a smaller converter 9.5 to 10 inc.. Recently just switched from 3500 to a 4100 and my 60 foot improved significantly
70 longbed
496/th400/Ford 9"
