12-07-2013, 02:27 AM | #1 |
cummins swap crossmember
So why is it so hadr to buy a crossmember for a cummins swap? Avalanche is long gone, Seeman is impossibile to deal with , can't e-mail , full voice mail. Anyone who sells one is either gone , hard to deal with or insanely expensive.
I was hoping to have a crossmember that was nearly bolt in, I have limited shop time right now and I would like to get the engine mounted and t case mount mocked in a weekend. Once I had the engine in a rolling chassis it would be a lot easier to deal with. Anyone know of a company with a good reputation or an indvidual who makes a set up? Thanks Keith |
12-07-2013, 08:58 AM | #2 | |
Re: cummins swap crossmember
Making a cross member for me was way easier than ever thinking about buying one. That can be done in a weekend for sure with the mockup etc. What about the engine mounts? Do you plan on buying or making them? There are lots of options. You could also have it a "roller" without the cross member until you buy or make one later.
BRIAN 1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater. My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509 |
12-07-2013, 02:46 PM | #3 |
I realize it's not a huge job , but I'm starting with a bare frame on a Saturday morning. Rails and cross members and nothing else. If I can buy a pre built pre engineered crossmember to support the engine its going to take some of the stress off. I have to do lift kit, diffs steering brace and more I'm sure I'm not thinking of in two days. A pre built crossmember would speed things along.
12-12-2013, 05:06 PM | #4 |
6>8 Plugless........
Call Dawna at Auto World. Is it pricey, yes, but a lot of time goes into making a quality cross member and mount set up. Especially if you make it to resell. Guys lay claims how fast and easy it is to make them but none of them are mass producing them. I always build each truck to fit each truck so my cross members never get duplicated because each build I've done isn't the same. Every part I've gotten from Auto World has been nice and they help me a lot with odd questions. They are very busy so you might have to wait on hold or Dawna may have to call you back. But I'd rather give them money for a nice part than some of the other stuff I see being sold on the net. 406-727-8915
http://www.cumminsdieselrepowers.com/Crossmembers.html
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-21-2014, 09:52 PM | #5 |
How did you make out with the cross member? Any updates?
02-27-2014, 12:43 AM | #6 |
I purchased a premade crossmember from rob Bonney fabrication in Arizona . Quality is great and I like the design , it has a removable center section for service. I have everything now . Just waiting for the snow to melt!
02-27-2014, 09:40 AM | #7 | |
What are you doing for the engine mounts, premade as well?
02-28-2014, 12:56 AM | #8 | |
And I may have a line on driveshafts. I will certainly start a thread as soon as I get rolling. Keith |
04-06-2015, 01:10 AM | #9 |
Do you have a pic of the cross member?
04-06-2015, 09:49 AM | #10 |
This is the original build that Rob started his production off of. I'm not sure if the design is different or not by much, but the skid plate stuff isn't part of the 'kit' Rob is a very nice fellow and does impressive high quality work. His are built to order I think. He has some info on 4btswaps under the name rubebonnet
https://m.facebook.com/1935597507644...pe=1&source=42 |
04-21-2015, 03:01 PM | #11 |
have one of robs crossmember,airbox mount, and dual bat trays, have not installed anything yet.... great guy to deal with and awesome products. its not a bolt in deal though does require welding and some fab work
05-21-2015, 09:36 PM | #12 |
12v and 24v engine mounts are the same. The only difference was if it was used in a medium duty or heavy duty truck
63 c10 5.9 cummins |
05-21-2015, 10:02 PM | #13 |
My 89 d350 and my buddys 91 d350 dullay have/had different mounts form the 3500 24v that I just pulled my nv4500 from so no they are not all the same.
05-22-2015, 05:49 PM | #14 | |
1st gen and 2nd gen dodge pickups are not the same. Med duty, heavy duty, industrial have many different styles as well.
05-22-2015, 07:45 PM | #15 | |
Correct as well. The oem mounts are not the same. But, the blocks are all the same. You can take an industrial 12v block and put it in a dodge. You can do the same with a 24v. Cummins incorporated all the holes in their castings due to production costs of several different casting designs.
