12-08-2013, 07:49 PM | #1 |
DIY Tailgate Repair
I got my tailgate back from sandblasting and had a little surprise, the PO had covered up two pretty bad dents in the lower part of the tailgate with body filler.
Not having $500 to buy a new tailgate I decided to try and make my own patch panels and this is how I did it. First I cut out the dents I used a straight edge to find where the dent started. Then I marked for my cut lines I used a cutoff wheel to remove the bad section. I was surprised to find out how little rust was on the inside. I measured the inside diameter of the curve on the piece I removed and it turned or to be 1.4 inches. I checked my junk pile and found that the lower control arm pivot shaft that came off my front end was just the right size to use for making the bend. I then got a piece of 16 gauge steel from the local hardware store. I spread the jaws of my vice as much as I cued and the use a hammer to bend the metal around the shaft. I tried to make the bend without tacking the plate to the shaft but it didn’t work After that it was just a matter of fitting it up and welding it in. After a little body filler it was good as new. |
12-08-2013, 08:01 PM | #2 |
Re: DIY Tailgate Repair
That's very cool.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
12-08-2013, 08:38 PM | #3 |
Well...its a nice job but most of that could have been fixed using a stud gun and the proper hammers.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
12-08-2013, 08:42 PM | #4 |
Moderator
Nice job, I would have tackled it the same way.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
12-08-2013, 09:18 PM | #5 |
Good job man! Did something similar but was just practicing bodywork since I've never done it before.
12-08-2013, 09:21 PM | #6 |
sorry, can't seem to get more than 1 pic to load at a time.
12-08-2013, 09:23 PM | #7 |
Fortunately I have a replacement tailgate I bought used a few months ago.
12-08-2013, 10:03 PM | #8 |
Nice work came out great
12-08-2013, 10:12 PM | #9 |
nice joerb!
12-08-2013, 11:49 PM | #10 |
Great job, I used an old rusty gate to repair similar po work on my gate. Glad I wasn't the only one, yours looks better though, I'm not a good welder IMO.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
12-09-2013, 12:00 AM | #11 |
More than one way to skin a gate. I would have used my stud gun & puller. Yours looks great though.
12-09-2013, 12:13 AM | #12 |
well it depends on the tools and the skills that one has. I think that he did a wonderful job of improvising. you use what you have sometimes.
ron |
12-09-2013, 10:01 AM | #13 |
Thanks for the positive responses, I wish I had a stud gun and puller but like most of us I have limited funds so we have to make due with what we have.
12-09-2013, 10:31 AM | #14 |
Awesome job! Would a stud gun and puller have resulted in a better finished product? I doubt it! A quicker repair, perhaps, but no better than what you did with what you had at hand. Improvise, adapt, and overcome. Thanks for sharing!
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
12-09-2013, 01:00 PM | #15 |
pretty thick metal for just a stud gun. you probably need a torch also and then filler. nice job doing it your way.
1961 chevy K10 my build is------------61K10 build |
12-09-2013, 08:08 PM | #16 |
I like the way you solved the problem. Good old fashioned PLANNING and INGENUITY. The result looks great! A good stud gun is not cheap and not everyone can get their hands on a loaner. I have one and they are rather simple to use but I would guess that if it was your first time using a stud gun, that you did it faster your way, and cheaper too! I think you are to be commended for a great job and also for sharing your DIY photos.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
12-10-2013, 11:12 AM | #17 |
Gosh. Look how thick that metal is. Thats why I love these old trucks. I accidentally left the tailgate down on my 2011 with a trailer on it and the wheel crank buckled my tailgate like it was made out of Reynolds Wrap.
No Weak Links |
12-10-2013, 11:21 AM | #18 |
Nice job on the repair
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-10-2013, 09:36 PM | #19 |
What are the red and orange arrow things for? Even though don't know what they do exactly, I probably need some.
12-10-2013, 10:03 PM | #20 |
