Old 12-08-2013, 10:31 PM   #1
Kaotik Kustumz
Kaotik Kustumz's Avatar
Question ? Bout '73 stepside.....
Ok guys I got a '73 stepside and would like to swap the front clip to either a '85-'87 front clip or a '89-'91 burban front clip......
Could somebody tell me if I could swap this out and what would be required to this and if any modifications would have to be done to make either one of them work and fit correctly........
I was told I gotta cut slots in the cab for the newer hood hinges and also gotta trim the frame horns to work also.....
Is this true or will it work with no issues?
KAOTIK Kustumz
1984 Chevy 1 Ton Crew Cab Dually "Western Hauler"454, th400, (6.0, 4l80e Swap Coming Soon)(5/7 Drop Coming Soon) (ON HOLD FOR NOW)
1986 Chevy 1/2 Ton LWB Silverado350, 700r4, (5.3, 4l60e Swap Coming Soon)(4/6 Drop)
Kaotik Kustumz is offline   Reply With Quote
Old 12-08-2013, 11:15 PM   #2
Doug_J
Doug_J's Avatar
Re: ? Bout '73 stepside.....
Here this should help same general idea.
http://forum.73-87chevytrucks.com/sm...ic,9070.0.html
Doug_J is offline   Reply With Quote
Old 12-09-2013, 07:51 PM   #3
nekkidhillbilly
idk if id swap a 73 front for that. you have the most desired front end by far.
nekkidhillbilly is offline   Reply With Quote
Old 12-10-2013, 12:45 AM   #4
KrazyRay
KrazyRay's Avatar
I just did this to a 78 dually. I cut the slots for the hinges and welded some flat bar to mount the hinges. I drilled a couple of holes for bolting the hinges in the flat bar. It was pretty easy to put the 86 front clip on and it was hard to see the mod because the 86 foam rubber hinge grommet hid all of the work.
KrazyRay is offline   Reply With Quote
Old 12-10-2013, 08:00 AM   #5
walkerb
walkerb's Avatar
Why the change from a 73 to a 85 clip? Looks or is the 73 front wasted?
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
