12-10-2013, 09:26 AM | #1 |
Starter for 383
Hey guys... Question for the stroker dudes on here. What starter did you use on your 383 stroker? I have a dual drilled block to take either the straight or cross drilled starter, with the 168 tooth flexplate. Is there a gm application that works well? Or are the high torque after market better? Thanks.
12-10-2013, 09:40 AM | #2 |
Re: Starter for 383
1970 LT1 350 starter from orielly's 50.00 bucks and turns my 10 to 1 compression 468 bb like its not trying. I don't remember the part number but I found it from another member.
12-10-2013, 10:02 AM | #3 |
Re: Starter for 383
Ive owned a couple 383 chevy motors , any standard starter is fine , the compact powermaster starters have allways worked well for me
12-10-2013, 10:08 AM | #4 |
Re: Starter for 383
I read somewhere a standard small block starter will have meshing issues with the 168 tooth flexplate.... Not true?
12-10-2013, 12:57 PM | #5 |
Re: Starter for 383
Thats because you are supposed to shim them. I never do, just drop the old one and put whatever shims are there back in. Shimming is done with a paper clip. Scientific aint it.
12-10-2013, 03:16 PM | #6 |
Re: Starter for 383
Funny but true I used to have grinding issues , but the paperclip feeler gauge is the real deal , works great
12-10-2013, 10:27 AM | #7 |
Re: Starter for 383
168 tooth flexplate is standard on all sb and bb. some early sb had 153 tooth flexplate. you will not have any problems.
12-10-2013, 10:33 AM | #8 |
Re: Starter for 383
Ok. Good to know. Newbie to the stroker world. Thanks
12-10-2013, 12:24 PM | #9 |
The Older Generation
Re: Starter for 383
12-10-2013, 12:32 PM | #10 | |
Re: Starter for 383
12-10-2013, 03:23 PM | #11 |
Re: Starter for 383
So... after reading attatched post link.. I called NAPA. There are 2 mini starters available for the 96-98 vortec 350. (if I was to take that route) mini starter and mini gear drive. (for twice the price) Thoughts?
12-10-2013, 04:38 PM | #12 |
Roto Reuter thats the name...
Re: Starter for 383
I used a Powermaster high torque mini starter, something like this. Just make sure you check the clearance.
http://www.summitracing.com/parts/pwm-9612/overview/
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
12-10-2013, 04:39 PM | #13 |
Re: Starter for 383
12-10-2013, 05:00 PM | #14 |
Re: Starter for 383
I have a Tilton High Torque mini-starter... bolted right up, no issues and fits under my headers..
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
